Daily Driver Tires
sareljr
I'm wondering, will a all terrain tire generally last longer than a mud tire on a daily driver? I have an 05 2500HD and I can't decide, MT Baja ATZ or MT Baja MTZ. I just need a tire that'll last long and perform well. Anybody run any of these two Mickey Thompson tires?
I've heard mud tires are pretty bad in snow but they look great, does anybody have experience with either a MT Baja ATZ or the MT Baja ATZ P3?
MTs can be worse than all seasons in snow. Snow is all about siping and MTs don't come with it
Sent from my SAMSUNG-SGH-I537 using Tapatalk
I live in an area where we only get snow about two or three times a year but I'd like to have decent traction in it, what is siping?
Siping is part of what makes tires good in snow. The rest is compound. This pic shows my Cooper ATP tread which is a "mud & snow" tire. You see the little sipes on top of each lug.
625D3027-D414-4A0A-9075-334457931BA3-519
Oh I see. Does anybody run a mud tire on a daily driver?
I did I spring and summer on my old 2000. They were awful (scary) on ice so during winter input a set of ATs on
Ryan
What All Terrain tire would you guys recommend? I know the BFG AT KO, and then The Mickey Thompson ATZ's. I'd really like to get the BFG All Terrain with the white lettering on the sidewall, but I haven't found any in my size, 285/75/16, just found the blackwall. yze9a2us.jpg I just think the white lettering would look pretty neat on my truck. What about the Goodyear Wrangler Duratrac?
I had BFG' AT's and I liked them in winter too. The only reason I switched from them as an issue with the weights that I discussed in another post. I decided to try Durotracs and I love them. They work great in mud ( way better than Nitto Terra Grapplers) and they are winter rated and work great in snow.
I run bf and have little issue, and I'm pretty much always snow and ice. Supposedly cooper at3 are better on ice, but hopefully it will be a year or so before I have to look into that.
Think I might just look for some All Terrain BFGs. I found this pic on the Duramax Forum website.aguqeru4.jpg it's a 285 and looks pretty good on there.
What is this "snow" y'all speak of? :lol: Here in Arkansas, if it snows we just stay home.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
