WeatherTech DigitalFit liners / mats
TechSTL
Just received my front Weather Techs today and installed. Same quality product as the ones that I put in my last couple of trucks.
  • Replies 47
I have weathertech s in my 14. I like them better than the husky s I had in my 08. I do think the wts feel slightly strange underfoot on the drivers side.
They came in handy when I tried this trick
  • 3 weeks later...
I have the WeatherTechs (in black) front and rear (Crew Cab). Love 'em. They are so much better than the original mats (which, as others have stated, are partial mats at best). These cover so much more of the floor... fit very tight to the floor, and catch everything. I'd take a picture, but right now they are covered with salt from our wonderful weather here in WI. (BTW, bought both front and rear from WT's warehouse near Aurora, IL for $200 total).
WIll probably get some carpeted mats for the warmer months - but only if I can find a set that fits as good and covers as much as these do.
  • 1 month later...
I guess I'm getting old. I have the tan/cocoa interior and ordered my weathertech in tan. I hate a dark interior and the dark carpet so I'm happy now. They match the seats real well and lighten up the interior enough for me. I have had weathertech in my last 4 vehicles.
  • 1 month later...
Anyone with the WeatherTech mats care to share a picture?
I ran across this picture in another thread and was highly disappointed at the fitment. Before I spend $200 on a set of these floor mats, I want to make sure they fit well.
http://www.gm-trucks.com/forums/topic/160178-cocoa-dune-interior-floor-mat-colour-choice/?hl=weathertech&do=findComment&comment=1439836
Selling my black WeatherTech set from my 2014 Double Cab. Details in for sale section or Send me a PM.
I think that's probably shipping/handling issue. A heat gun and some patience would fix it.
  • 1 month later...
Do the WeatherTech and Husky Liners use the OEM retention system? Still trying to decide between the 2 for my new 2014 CC. Having a had time getting a feel from the posts on how they compare.
Yes. I went With the Husky Weatherbeaters in my Double Cab. Perfect fit.
I have WT liners in mine and they use the factory retainers and fit like a glove. Front and rear. I have cocoa/dune and went with tan.
Would it be possible for you to post a picture of the drivers side?
I saw another post that someone said their Weathertechs were curling up on the passenger side and shifting around have you had any issues?
P.S appreciate you feedback
No, I haven't had any trouble with mine. They've only been in the truck for two weeks though. But no problems. I've had a front/rear set in a Tahoe for a couple months with no problems either.
I ordered my set from eBay I got a deal at 185 shipped I think.. Took 3 days and I love the mates. Highly recommend them to anyone the fit is legit. Also have the no drill mudflaps I hope to install tonight.
I also have the No Drill Mud Flaps and they fit perfect. My WeatherTech Floor Mats will be here tomorrow.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
