2 hours ago, b-garage said:
Well that IS interesting. The way Frank had all the part numbers listed out made it appear that those other pieces did not come with it. Like they were all ordered separately.
Who's gonna be the guinea pig and order one to find out....hahah?
GMPartsNow.com has a reasonable return policy so maybe. Need more people to call them up and ask if this is correct for verification.
its the shipping back that gets you. I could get that console shipped to me cheap but if its wrong...thenI pay to ship it back. For what its worth my console came freight on a pallet via fed ex and it was 30.00 to ship. It would certainly cost more than that to ship it back. This console has a cheaper price than the one I ordered of basically 30.00. Though mine came with a 2017 wireless module. If this thing is complete, and comes with a 2018 module that would be really interesting and is a decent deal.
I will call tomorrow and ask. Will ask too if it turns out to be not what they say it is, if they cover shipping back. Would think if you provide a valid vin# and get them to confirm it is the complete assembly that it would go back on them to pay shipping back. But need to confirm with them first.
Edited by b-garage
From GMPartsnow website:
Quote
The cost of shipping will be credited only in those instances that the return is a result of our error.
I sent them an email instead of calling. That way I have something in writing as well. Will let you know what they say as soon as they respond.
Apparently that is a complete assembly with arm rest lid with wireless phone charging and back cover.  I sent GMPartsnow an email inquiry with the VIN from a 2018 1500 LT 2WD truck.
Jim from GMPartsnow responded with a quote:
Order Content
Part Number
Make
Part Name
List
Price
Quantity
Total
84193710
GM
Harness
$35.87
$23.93
$23.93
84288040
GM
Console
$571.33
$387.36
$387.36
22776807
GM
Console Assembly Front Bracket
$22.10
$16.58
$16.58
23467516
GM
Side Trim
$35.73
$25.08
$25.08
22817347
GM
Side Trim
$77.43
$52.50
$52.50
84092080
GM
Upper Trim Panel
$214.28
$145.28
$145.28
11609982
GM
Fender Liner Bolt
$4.57
$3.26
2
$6.52
Subtotal Amount:
$657.25
Order Content
Part Number
Make
Part Name
List
Price
Quantity
Total
84193710
GM
Harness
$35.87
$23.93
$23.93
84288040
GM
Console
$571.33
$387.36
$387.36
22776807
GM
$22.10
$16.58
$16.58
23467516
GM
Side Trim
$35.73
$25.08
$25.08
22817347
GM
Side Trim
$77.43
$52.50
$52.50
84092080
GM
Upper Trim Panel
$214.28
$145.28
$145.28
11609982
GM
Fender Liner Bolt
$4.57
$3.26
2
$6.52
Subtotal Amount:
$657.25
Yep, I got the same answer!
I still emailed gmpartsnow back asking for some sort of confirmation that the console part # does come with the lid and back cover, but nothing back just yet.
I finally got an email confirmation from Jim at GMPartsnow that the console assembly 84288040 does come with the arm rest lid and back cover.  So I ordered everything today.  Will let you know if they were right when it gets here for sure.
Cool! I plan on getting my order in this week as well
that was using a 2018 vin right? Id be intrested to see what it all looks like.
Yes sir.  The upper trim piece is now on back order though.
I'm most interested in the back panel and what wireless charger you get
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
