does 2018 fit 2016 silverado?
Physically, yes.
Does anyone have the parts list for the cocoa interior? Interested in this as well
This is a parts list for the dark Ash interior in my 2017 z71 lt. I think the website I used is a little bit more expensive so I’ll have to shop around, just wanted to get a quote from a different place.
On 3/16/2018 at 1:23 PM, b-garage said:
I still emailed gmpartsnow back asking for some sort of confirmation that the console part # does come with the lid and back cover, but nothing back just yet.
So what is the updated parts list ?  I'm doing a swap for my buddy but you said some parts aren't needed?
The question was whether 84288040 actually comes with the updated  wireless charging armrest lid and the back cover. GMPartsnow says it does.
This is the quote I received from GMPartsnow that I posted on the previous page of this thread. This is what I ordered last week. Suppose to be here Monday 3/26. I will let everyone know what shows up after I receive it.
Regards,
big rog (b-garage)
Jim from GMPartsnow responded with a quote:
Order Content
Part Number
Make
Part Name
List
Price
Quantity
Total
84193710
GM
Harness
$35.87
$23.93
$23.93
84288040
GM
Console
$571.33
$387.36
$387.36
22776807
GM
Console Assembly Front Bracket
$22.10
$16.58
$16.58
23467516
GM
Side Trim
$35.73
$25.08
$25.08
22817347
GM
Side Trim
$77.43
$52.50
$52.50
84092080
GM
Upper Trim Panel
$214.28
$145.28
$145.28
11609982
GM
Fender Liner Bolt
$4.57
$3.26
2
$6.52
Subtotal Amount:
$657.25
Edited by b-garage
Alright guys so I've done tons of digging and I apologize. But all I am seeing is people discussing for the newer year silverado's. I have a 2014. How exactly do you go about getting the exact part list to do the center console swap?
Find a truck with the exact color console and options(such as wireless charging) and get the Vin number. Call or email a gm parts supplier( I used GmPartsNow) and give them that Vin and tell them you need a complete list of everything needed. They should email you with a list and a link.
FYI I used gm parts now and used promo code “quote10” at checkout and got 10 percent off my order. It’s. It a whole lot, but it payed for shipping and then some.
Awesome thank you. Looks like I will have to go looking at some trucks at dealerships to find the console and same trim that I have. Thanks!
I used auto trader and found one online while at work(don’t tell my boss)  saved me a bunch of time and a trip to the dealer.
I actually just did the same. I found a 2017 same trim which is reverse tartan. Only difference is it has leather seats and mine is cloth. Now this may be a dumb question. Does it matter if it is a 2017 or do I need to specifically find a 2014?
I don’t think it matters. It’s actually better because you get wireless charging. But I would maybe check out the first few pages and re read that. Or maybe @pgamboa can chime in. He’s gotta build you a custom wiring harness anyways so he may know better.
Any console from 2014 to 2018 will fit your truck.
I have a 2018 Rally 2 and I'd like to install the console. While looking at similar trucks for part numbers I noticed that some of the trucks have 4 port covers for the 110v, USB, etc. and others only have 3 covers. How do I tell which setup would be compatible with my truck?
I just did the same and requested a quote.  I'll post it here once I get it back.  (secretly hoping the price has gone down)
Edited by BluEyeItln
On 3/19/2018 at 9:38 AM, b-garage said:
I finally got an email confirmation from Jim at GMPartsnow that the console assembly 84288040 does come with the arm rest lid and back cover.  So I ordered everything today.  Will let you know if they were right when it gets here for sure.
Here is what came with my order...
IMG_3862.JPGAlso rec'd the side plates, bolts, bracket and cables, just not in the pics.
Edited by b-garage
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
