Do you have to order the top cup holder, USB, Power Plug section separately?
Yes. You have to watch part numbers on that one depending on what trim color you have.
5 hours ago, b-garage said:
Here is what came with my order...
IMG_3862.JPGAlso rec'd the side plates, bolts, bracket and cables, just not in the pics.
Very nice. Open the lid and see what wireless charger came with it also take note of the part number on the Mat itsself!
This was the part number on the lid 23264394.
Not the lid, I want the part number on the mat it's self
Sent from my SM-G965U using Tapatalk
Sorry, thats what I meant. Thats the number on the mat itself.
so you have it that far apart....lol what charger is in that bitch?
No, that number is on the mat.
From the picture on the mat looks like the wireless charger to me!  So the console in question is in fact the new 2018 console with wireless charger?
he will need to take it apart to verify for sure! Pgamboa has a tutorial on it but basically it just pops off. its kind of a bitch to get off though. its eaiser if you have trim tools.
If you have the reverse tartan trim (cross stitched silver) it is 84092079
I counted 10 ribs on the mat is that correct? Have you had a chance to verify if that was indeed the new wireless charger.
Does anyone know if the center console for the same year ranges of the Tahoe/Suburbans can be put into the Sierra/Silverados?  They look exactly the same and there are far more of those up for sell than the ones listed for Sierra/Silverado.
No they are different
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
