The harness from the dealer or any other online retailer will not work if you are swapping out the for the console.
Is anyone wanting to buy my floor console? I did the swap on my 2015 Silverado but I am now trading my truck in. It will come with everything less the 12V Plug, cigarette outlet in the top plate and the jump seat harness. My console has the charging pad on the armrest. $550. I’m located in North Central Wisconsin
Johnny01: IF you could pm me and let me know if you take paypal, OR what method of payment it would take? And also send me more pictures of the console from different angles. EMAIL ADDRESS is [email protected]. THANKS.
Sent from my SM-G935V using Tapatalk
On 4/3/2018 at 10:18 PM, z71tx said:
Anyone in the West Texas area need a black console? I ordered a what I thought was cocoa and I received a black instead. Still waiting to hear back from gmpartsnow. The Vin I gave them was for a cocoa interior...
Do you still have this?  Please check PM. :)  MR
On 4/1/2018 at 10:56 AM, bpaz7 said:
Hey guys I’ve been reading this thread and saw gmparts online had some stuff on back order I found this site and just ordered my stuff threw them The parts seems to be a little cheaper I didn’t try any cupons cause I didn’t want to wait! Anyway here is the breakdown hope it helps
Was this a complete console?  Came with the back piece, console lid etc?
Im not sure whats up with my post above lol. Anyway can some one do a test for me. I did the swap and android auto/carplay works from all usb ports. However reading media (such as music) only works off the glove box usb and the front usb. It does not work off the internal usb. Can some one else try it and see if it works for them.
Kinda opposite of what everyone else is doing but, who has gone from a full console to a jump seat?  Not sure I would do it but, I did like the jump seat setup in my 2014....
I'm wanting to change my black jump seat out for a center fool console. I'll send you a picture of it. It's in my 2016 chevy Silverado crew cab LT Z71 1500 and it's leather. Could you send me a picture of yours.johnny01:a885f7f33ad3f4671729455ae2989bdb.jpg
Thx for the interest but, I would need cloth as I have an LT w/ cloth seats and I am still not sure I'd wanna do the swap... More so just wondering if anyone has done it...
I have a cloth jumpseat with full wiring harness in tact that is nearly flawless if you are interested in purchasing.
22 hours ago, jacobrmiller05 said:
a few people have done it, but there will be a hole in the carpet that is visible.
Ah good point - I guess the cost of a new carpet OR an over the hump floor liner would have to be factored into the project...
Thanks for the offer, if I decide to go that route I will hit you up. Right now it sounds like too much work to make the swap given the other things I have occupying my time at the moment...
Just installed my swap yesterday, looks great and everything works well thanks to the great @pgamboa
Have 2 questions though for people who have fully completed this swap.
1. For the life of me I cannot figure out how to get the side trim pieces on with the console itself bolted in. Do these side trim pieces need to be installed with the center console unbolted?
2. Does anyone else's cup holders rattle with a drink in them when going over a bump? Trying to figure out what could be loose and how to fix it.
You just have to play with it a little I had my seats out
    d.lowrey
    d.lowrey
  • Who's Online   0 Members, 0 Anonymous, 3,063 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
