5 hours ago, pgamboa said:
Removed the magnet?
Yep and removed the plastic piece over top of it as well. I make my phone face the opposite way and charges really well now
What magnet. I have the 18 module. But my phone case wont allow the phone to sit flat
I don’t have the 18 module. I have the 16-17 module. Inside it there is a magnet, and a plastic sleeve that prevent the charger from working properly. I removed those and it works flawlessly
Maybe I should pop open the 18 module and see if it has that
Pretty sure the 18 module doesn’t. It has 3 charging rings compared to my 1 charging ring.
Hi
I recently bought a 2017 Silverado 1500 LT Z71, I have the jump seat, but I hate it. I want to do a swap to the full floor console. I have been reading the forum and been seeing alot of things that are not working. I dont want to lose features. I have been taking down the part numbers and what not.
However I cannot figure out the part numbers for black leather with black stitching.
Also I would appreciate any tips or things I should be aware of.
If anyone has any leads on a complete console shoot me a message.
5 hours ago, rae185 said:
Hi
Check out the first post, everything is plug and play and EVERYTHING works. No lost features
There's several part numbers listed in this thread as well
Johnny01: Contact Corbin at gmppartsnow.com and have him to send you a list and diagrams of all the parts. Pgamboa can fix you up with the PNP harness and he has a video on YouTube that shows you how to install all the wiring where everything works.
Sent from my SM-G935V using Tapatalk
I saw that video. I'm just curious as to what part numbers go to what colors and color stitching, and I will shoot gmpartsnow.com a email requesting Corbin to get ahold of me thank you.
Ok thanks so much!
On 5/6/2018 at 8:34 AM, frankinbus said:
Nope , Just did a swap in a W/T single cab , Looks awesome , with floor shifter for 4 wheel
Do you have a picture of it? I have the floor shift also.
Thanks
Edited by DONWT15
Your best bet and what they will ask you for is a vin number.  What I did was searched cars.com and any other vehicle sites for the truck that has exactly the console you want and then give them the vin from that.  That is the best way to match it up.  Those guys are very thorough in making sure its complete.  I can send you my quote but, its somewhere in this thread as well.
  • 3 weeks later...
I just got a quote of $912. I thought the console came with the armrest it’s showing in the quote I have to purchase it separate?
mitchell95: I just finished my swap. Ordered all partsfrom Corbin with gmpartsnow.com. I spent hours researching prices and they were by far the cheapest to the door. I have a 2018 Silverado Crew with black interior w/silver stiching.
84288040-Console $390.79
84092079-Upper Trim Panel $146.57
22467516-Side Trim $52.96
23467516-Side Trim $25.30
22776807-Front Bracket $16.58
84022323-Cable $16.46
19119050-Cable $24.13
11609982-Bolt x 2 $3.26ea
Total $680.31
10% Discount -$67.93
Shipping to my location $54.53
Grand Total $665.91
You will also need the wire harness from pgamboa he will hook you up...
Hope this helps
I will admit my mistake, I hadn't quoted one in a few weeks so it was my mistake adding the lid when it was not needed. That is why his quote was higher.....my bad!
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
