I have black trim off a new 2017 crew cab that I would like to trade for chrome. Let me know
Regards,
rog
I have a 15 with great chrome ones. Are they the same?
2018 double cab wanting to trade my chrome for black
I have a 2015 crew cab with black window trim on the bottom, would love to find someone with chrome who wants to swap out.
Also want chrome door handles, if anyone is swapping out their chrome (mine are the brown color matched version).
I have a 15 Sierra Crew, and I would do that to match my new black runners... My chromes are in perfect shape...
Looks like our swap fell through, so if anyone is interested in getting my black window trim for your chrome trim, I'm willing.
Edited by Slabsides45
12 hours ago, ajwcotton said:
Slabsides45 ill trade you chrome window trim and doorhandles if you still have them.
I do have them, but already committed to a set of chrome handles. If you're still up to trade your chrome for my black window sills, I'll do that. Sent you a message.  Thx.
On June 27, 2016 at 2:27 PM, sk said:
Did you break the clips? There is a smaller clip right in the middle of each clip. Usually the smaller "lips" break off when you remove the trim and you don't even notice it. If those little lips are missing the clips won't snap back into place correctly (sorry I don't have any pictures).
If the clips are still intact then I used a rag and a rubber mallet to tap down on the trim until it clicked back into place.
I found the clips if anybody needs replacements.
GM 11547339
Found a pack of 25 on Amazon for like $15.
Hey I’ve got chrome window trim on my truck if anyone is willing to swap for their black ones? Shoot me a text 512-37three-two883. Thanks
(2014 GMC Sierra)
I have chrome trim/handles I would be willing to trade with anyone who has Iridium. Off a 2014 Sierra. Let me know if interested
I have a set of chrome mouldings off my 2017 Crew cab available for $150.
Also have a perfect set of chrome door handles up for sale for $100.
Paypal preferred.
  • 10 months later...
Still got you black window trim? Trade for the chrome
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
