If anybody is about to take off and insert new window trim, think you can do a video. An its an easy feet, but some would just like the added confidence from watching someone else. If there's already a video out there, point us in the right direction.
anyone know if 1500 gmc sierra will fit a 3500 Silverado. everything I know tells me they are identical, but I want to be sure.
I hate this forum for giving me this idea haha. I broke all 4 clips on the first one (mainly because i didn't read this thread before trying it i was reading another thread). Keep in mind that the clips are so small you won't even realize you broke them until its way too late. Also I managed to be an idiot and I ripped the screw part out of it too. Such a dumbass I know..
Edited by Z71hayss
  • 4 weeks later...
I got mine off easy no broken clips and painted. They look great but has anyone had issues getting the back ones to clip back down? Fronts went straight back down both rears refuse.
might be a long shot...but im in DFW TX and willing to trade my chrome for your color matched sonoma red jewel tintcoat - door handles/mirror caps
i will even throw $$ for the trade.
might be willing to do black also as an option - but prefer the color matched.
respond or PM
Edited by JUSTINASS
I took a 1" or 1 1/2" putty knife and put a small bend in it with the bench vice. It worked great. Did all four window trim molding in about ten minutes...
I did have a problem getting the clips to seat. I ended up closing the doors and almost doing a pullup off each door. After doing that all the clips did seat
I currently have a new 2015 white crew cab ltz with all the chrome trim. Anyone interested in swapping some color matching trim? Moldings/window trim/door handles/ mirror caps? thanks fellas
Anyone in the DFW area wanna sell their chrome trim or trade for black let me know. Pm me or email [email protected]
i will...i have chrome and want black...straight up trade?
email sent to you...
  • 1 month later...
I have Crew Cab black window sills and am looking to trade for chrome. Anyone interested?
  • 3 weeks later...
I have had the black belt molding replaced on the front passenger side of my 2015 Silverado crew. In direct sunlight one can see discoloration and scratches. I ordered another one and it was just as bad. If I can't get one that is undamaged I may have to switch to chrome. They come with protective plastic on them to prevent scratches during handling.
Does anyone happen to have a video or pictures? I purchased a black set, but having a hard time getting the clips unhooked.
  • 2 months later...
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
