HOA Rant
RyanbabZ71
I like some aspects of HOA's like someone said; you can't paint your house bright pink but, it kinda limits the freedom to do what you want with your own property. I looked at some homes with HOA's and honestly for the first reason I stated I liked the idea of it. I live on about an acre on a rural road now, its not really a neighborhood or a sub division just a secondary road on the outskirts of town but, we do have some serious dumps on the road that need to be fixed up / knocked down I wish that I had an HOA for that but then again it's not my house so really its not for me to say how its kept up.
HOA's are ultimately a necassary evil for stopping neighborhoods from getting run down. Which is good, until you get one that goes section 8 and chases you up the parking garage cause they cant see your parking sticker.....
  • 1 month later...
HOA sounds like a terrible idea. Sure, they limit terrible choices being made. BUT, shouldn't I be able to do what I want with my own property that I purchase and maintain?
I, speaking just for me, will not be moving into an HOA area.....or hardly a neighborhood for that matter. I can't even see my neighbors house, so why would I care what color it is, or what kind of pool is in the backyard? Again, why would I care about his house in the first place?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
