2014 6.2 exhuast power loss
Bvonscott
Well I am still searching for a replacement. I have been watching all these videos to hear the sounds. So far I like the Borla ATAK, Corsa Extreme, Corsa Sport, and the Super44 I have now. I want a loud aggressive tone. I don't care about drone or whatever and I don't want cherry bomb and I don't want glasspacks. But those guys don't have any exhausts developed yet for the new 6.2. So I may have to get a Borla XR-1. Or see if Corsa will sell me a muffler. Hmmmm
UPDATE: I had my local muffler shop put a magnaflow 14" on in place of the flowmaster... That did the trick. The engine woke back up big time. Throttle response is lighter, man the flowmaster felt like it was dragging on the truck Im sorry to say. I smashed on it from a light and i noticed a huge difference. Anyways, I called borla they might consider using my truck to develop the ATAK system for the 6.2 but they havent called me back yet. As far as the magnaflow, its not as loud as the super44 at all. Soooo, if borla doesnt use my truck for development, I am getting the XR-1 sportsman 3.5" in/out 12" case. So the message here is if you have a 2014 truck DO NOT get a flowmaster. Sorry to those guys but they need a straight through for these new trucks.
Not enough back pressure. Anytime you change pipe size it also changes your horsepower and torque range. 4" is too big. 6.2l really only need 2.5-3" exhaust. There is not enough horsepower and torque until you get over 800hp power range. For that size exhaust. Your losing your power over 3" exhaust
BINGO!!!, I 100% agree with this analogy.
My 1st reply to this would have been to try a different muffler and/or there could have been some narrowed bends if the muffler shop didn't have a mandrel bender. So there is another flowdisaster experience. Flowmaster will increase your sound but thats about it. Never liked them based on experience. I worked at a performance shop for years and can't tell how many people we up sold to Magnaflow, Hooker Aerochambers, Borla, or Corsa with improvements of the FM every single time. The 1st two I listed were the most popular we sold but all those choices always increased power on anything we installed them on. Glad to hear you have it resolved!
I can promise you it had nothing to do with back-pressure topic per say but more so that Flowmaster is a very restrictive design muffler and now you are running a straight thru muffler with less resistance. So you could say it was a back pressure issue, as in too much back pressure versus the more free flow thru design the factory muffler uses.
I personally can attest to the HP that Flowmaster can rob from a vehicle. I had a 2001 Formula that was pretty stout for what it was back in the 2004-2005 era. On some advice of my local tuning shop they suggested I change out the Flowmaster cross flow muffler for a Magnaflow muffler. We dyno'd the car before and after the change. Car only had a SLP Y pipe and a welded in muffler. Cut the Flowmaster out, welded in the Magnaflow in it's place. Spun up the rollers and was rewarded with a 8rwhp increase.
Flowmaster may sound better, but Magnaflow sounds smoother, flows better and you wont have issues with the baffles breaking loose down the road once the condensation rusts the baffles apart.
Exactly! The F-body cars were the worst with Flowmaster because of the crossflow design! We saw cars pickup 10-30rwhp depending on the engine mods and usually a couple mph at the track so it wasn't just a dyno number. Spintechs are another joke. Sound is awesome but horrible on power! I picked up 10rwhp going from a Spintech muffler to Hooker Aerchamber on my 91 Camaro. And this was on a 3.5" mandrel bent exhaust system.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 391 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
