Mine is a 4 x 4 with 4:10 gears
yea!...4.10 is the way to go
2014 2500 HD, 4.10, 2wd, stock, 6.0 gas, long bed / reg cab.
I tow approx 10K (twin axle metal deck utilitiy style trailer / car hauler) trailer weights 3K, truck I tow weighs appx 6k...plus misc gear.
around 9 flat ground....worse in the hills, I generally run 70-75 on the hwy.
Towing a 8200lb travel trailer behind a 2001 2500HD Duramax I see about 11 on average.
Not sure I will like what I am going to get towing with a 5.3L Max Tow 1500. Thinking 8ish. But I will do a lot better not towing.
On a recent camping trip I averaged around 12mpg towing my approx 6k TT. Not tobad considering the truck only had about 1500 miles on it it at that point. My old 2000 ford expedition towing the same roof was around 8mpg or so.
  • 2 months later...
'07 Escalade ESV, 160k miles, all stock, 265/65/18
Towing 24' Express cruiser, about 7500lbs
Photo - Purchased truck 3-days before 2500 mile road trip to pick-up (just purchased) boat. Found that the rear shock air boots were blown ... no leveling (plus a few hundred pounds in the back).
Highway only :
Below 70mph = 10.5 to 11 mpg
Above 70mph = 9.5 to 10 mpg
Tucking in behind 40+ foot trailers = gain of about .5 mpg
Our last two 3/4 ton Sunburbans, both 2001s (had 28' Express Cruisers at that time, 10k+ lbs), one with 6.0 and other with 8.1, both got just below 12-mpg on highway UNLOADED. Got 10-mpg average daily use .... if not hot-rodding around. Never calculated towing MPG.
Edited by M3eater
  • 5 years later...
normally get 18.734mpg in a 2017 silverado crewcab e assist 4x4 empty. towing a 4800lb rv i usually get 8.7 mpg.... OUT WITH THE OLD.... about to pick up a 21 rst crew z71 3.0dirtymax..... should be better towing mileage with that.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 408 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
