Getting a P0300 random misfire for my 2001 Silverado Z71 5.3
as i was driving my truck i got a flashing service engine soon on my dash, went to have it checked and got a P0300. the mechanic said it was misfire on multiple cylinders with a lean on 1357 side. he checked all the spark plugs and wires, coils even went and had the injectors cleaned. this was done to both sides. the code was erased and next day same thing happened. what can it be?
A GM truck?......
after 16 years of owning my 97' GMC, I have totally given up trying to find out what triggers this misfire condition. After about 3 years of owning it, I bought a cheapy code reader so I could plug into OBD-II port and simply clear the codes and get that check engine light to go off.
I had a P0300 and P0171 code pop up last week and it was my O2 sensor on bank 2 sensor 1. I've also had to replace an O2 sensor when truck read P0300, but it was bank 1 sensor 2.
I have a 2005 silverado Z71
Why did the mechanic only look at ignition system for misfire? Did he ignore the other message about lean condition?
The lean condition will also cause misfires. Look for vacuum leak now. Intake to cylinder head is pretty common. Vacuum line condition should be checked as well. Brake booster can also be a vacuum leak. Point is, always do basic checks first, before changing parts.
Had the same problem, was told to replace wires, plugs, intake gaskets. Did all that didn't fix it. Found this forum and Wrencher said bad upstream O2 sensor on driver side. Low voltage to sensor sends lean code, which in turn sends more fuel to bank 1, resulting in multiple missfires. Replaced $40 O2 sensor and truck runs great. Wish I did that first. Good luck
Had o2 sensor code go on then while driving it started to drive terrible so brought it to check codes again and now I have p 0101 code also I changed pass anger side after converter sensor and the spark plugs but still runs terrible I don't know what else to do
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
