Black puff of smoke at start
jallen2014
I noticed one thing on DI engines is that my used oil analysis come back with "high" fuel dilution. So with the severe cold and the fact that the dynamics of the engine getting that much more fuel to start means the cylinders are getting washed down on start up.
Like in the old days when I had to choke my 65 Impala's big block, it would puff black smoke out the tail pipe until I could get it to run smooth and feather the choke. It didn't like the cold one bit. Fuel injection has really made vehicle starting so much easier.
I wouldn't think it is normal to have black smoke puff out on start, but then it is a new design. It wouldn't hurt to get it checked out and the issue logged in to the system so if there are any issues later on down the road you have documentation while still under warranty.
  • Replies 80
Thank you for this insight! I have a list going for when I get days off work to take it in.
My truck did it this morning on startup it only has 200 miles on it and was about 35 degrees outside. I dont think it's a big deal it's hardly noticeable and even If it Is that's what the warranty Is for.
To me, its more what problems could arise in the future. I work at a job where I can't be stuck on the side of the road with a dead truck. That's why I buy a new truck. The stupid thing has already left me with a dead truck twice. It only has 2200 KM on it.
I never noticed the small puff of smoke until recently. I can't say its due to cold weather, seeing how my winter hasn't been any colder than the mid 40's. With that said, I didn't notice it until the cooler weather. Usually after it has been sitting a while. (First thing in the morning) However, I also did not notice it until after the "fire recall" was performed. I have been to my dealer about it, but I received the typical "can't recreate the issue".
At this point it's something to keep my eye on, and it's now noted in my vehicle maintenance history.
MY 2013 6.2 with the L9H engine was DI too and it didn't start like this, or puff black smoke.
Sorry to tell you this, but your 2013 6.2 if it was a GM product was not a DI engine. The only GM vehicles with 6.2 DI are the new 2014 Vette and the new 2014 1/2 ton trucks.
As said this is normal because of the extreme cold weather. Colder air is more dense, ECM is dumping more fuel to aid in start up otherwise the engine would be lean right upon fire up. I would also bet it is to aid in CAT light off as well with in the EPA mandated time to reduce emissions.
I can tell you from my research and watching my truck, winter fuel + really cold weather is good for really crappy mileage. As soon as it warms up I see immediate increases in fuel mileage once the outside temps are over 40°.
Well that was the excuse the shop gave me as to why it was ticking like it was going to explode... I'm not even joking. I didn't think it was either.. The puffing of black smoke is not normal. I've lived in a cold climate my entire life and this is the first time Ive seen this with any vehicle
But how many Direct Injection vehicles have you had? This is a DI characteristic.
Just this one I guess. But my '13 6.2 was ticking after about 4000 km. When I traded it off in january, it had 40,000 km, and it sounded like to motor was going to pile up. They kept telling me it's supposed to sound like that, due to it being direct injection. This was on a '13 Sierra, and GM techs. The '13 wasn't blowing black smoke. It just sounded like it had bad lifters to me. Dont ask me why I bought another GM after that experience, I dont know myself.
lol that 2013 6.2L was NOT direct injection. It was just standard port injection. Whatever techs told you that are idiots. If that motor was ticking badly, there was definitley something wrong with it.
I was so tired of pursuing it I just got rid of it. Took it into the shop 3 times over that.
Now here I am, once again.
Well here you all go, mine has sat for 3 days and I go to start and was looking for it and yes black smoke on start up. I did not have an extended crank time but did have the smoke. Also for everyone it was 80deg. today and started her in the afternoon. I am taking it to the dealer Tuesday for the rear end shaking, shaking under harder acceleration, and I will have them check this out. It also seems to shift really hard some times. I am at 1200 miles.
Its "Normal" lol. As someone once said at my dealer "we are the test mules". Mine smokes too and I live in south Florida. Mine as I said before smoked before and after recall reprogramming. I just stopped worrying about it and if something is wrong, I'll hear about it on the site here.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
