Black puff of smoke at start
jallen2014
Has anyone noticed a black puff of smoke when starting your 2014 Silverado? It's been pretty cold here in the mornings and I've started watching the exhaust pipe while starting my truck for the first time each day. I see a puff of black smoke! I only have 8k miles on it.
  • Replies 80
It's because of Direct Injection. Pretty normal since the vehicles tuning runs rich from the factory. Probably is a little worse with the cold so it using more fuel to start the engine.
Don't let Won_Hunglo scare you.
Happens with mine to. Really noticeable in single digits.. Of all the trucks I've owned this is the first with DI and first with the black smoke puff at start up. (Unburnt fuel)
Not normal at all. Are you saying the ones that do not smoke are broken & need service to make them smoke?
Yes. It is is normal. And no, just because a certain truck doesn't do it doesn't mean it needs service to make it smoke. That's moronic.
The OP said its been cold, so chances are he is in a northern state that uses a winter blend gas. The extra additives make it less pure and the cold weather doesn't help either. On start-up the motor needs more fuel to start so some is inevitably burned off. Hence the black smoke. All DI motors will have similar characteristics. Along with loud ticking injectors.
Stop being a jag and creating panic for new users, it's the last thing this forum needs.
If you don't have anything helpful to add, keep your typing to a minimum.
Amen^^
It is normal with DI engines - my Camaro and truck both do it when it is in the realm of the artic weather. My little six has not blown and is on its third winter and I noticed this the first winter - was a surprise to the dealer the first year as well because GM had not issued any bulletins on it - like someone said the DI and winter fuel with being a little rich causes it.
Same thing happened with me last week. Temps were -20 to -27 C (-4 to -16F) and man it sure took a while to turn over!
Was going to mention it to the dealer when I take it in for the recall
DI issues. Go to your dealer now before she blows.
Wow.
Just wow...
This is the first time I've seen someone say it's normal. Mine cranks about 10 times before it starts, after sitting for a night. Even with the block heater plugged in.. Once it turns over it puffs the black smoke. MY 2013 6.2 with the L9H engine was DI too and it didn't start like this, or puff black smoke.
When it was -20 my 2008 blackbear tuned Sierra Denali turned over much longer than normal and put out a little puff of black smoke. If it continues when it warms up I would be concerned but I would bet it's just the cold weather.
Black smoke on a DI engine start up is a leaking injector. On a DI engine, this can lead to cylinder failure.
It seems like pretty much everyone has this problem though. What are the odds of all of them having a leaking injector?
MY 92 chevy with a tune cold thermostat, s/c msd, been doing that since last rebuild 10 years now. It over fueling cause its cold should be fine. If not that little light that says check engine will come on, you can bet on it.
Hi jallen2014,
I'm sorry to hear of the concerns you are having with your 2014 GMC Sierra of black smoke upon start-up. Have you been to the dealership about this concern? I would like to assist you further. If you would like my assistance please send me a private message here on the site and include your name, phone number, address, VIN, current mileage and involved dealer. I look forward to assisting you!
Thank you,
Andraya R.
GM Customer Care
First year model run & a new engine for GM. Odds are good if it is a design issue most engines would have the problem. Problem is not everyone is having this issue. Points more to a defective part, not a design issue.
Seems to me that the people that aren't having the problem live in a warm climate though. I'm still going to take it in.
