Black puff of smoke at start
jallen2014
attachicon.gifIMG_0489.JPGHopefully this works! If it does then here ya go.
Yea, that will work. This should put the black smoke at startup debate to rest.
  • Replies 80
somebody please combine all these black smoke at startup threads. thanks
My brand new 2014 Silverado has this Black Smoke on Cold Start Issue.
When I called the dealer, they said "I hadn't heard that one" "no PI in my system".
I called GM Customer Service. Same story...
Called Dealership back with the #PIP5189: Black Smoke on Cold Start bulletin from this forum.
Surprise. They found it in the system.
Long story short. Bring it by for service evaluation.
I've got a bad feeling about this...
Check out these YouTube videos showing the problem.
Nice post. I can say that I've used nothing but Shell gasoline (which is Top Tier as that document says) since I bought my truck in February and I have no black smoke on start up. I'll occasionally see some white smoke at start up but it only lasts a few seconds and seems to be consistent with typical white smoke/steam from an exhaust system. My wifes Hyundai, which also has a GDI engine, does the same thing as my Silverado.
I see white smoke sometimes also. Maybe it's water trapped in the exhaust system and then heating up? I hope anyway.
For those of us who were wondering what top tier gasoline is: Here is a link to a page with a video about top tier gas
http://www.toptiergas.com
Edit: here is a list of the current top tier gas retailers.
  • 2 months later...
Well I might as well go ahead and add another 2 bits. Just purchased a 2014 kia optima sx gdi turbo for my wife. Maybe someone here could explain why this direct injected engine doesn't puff black smoke at start up if this is such a normal condition as others have posted. Like I said in my earlier post glad this smokerado of mine has a 160k warranty. We will see just how normal this really is as time goes on. IMO I don't think this is normal.
Maybe Kia uses a different cold start process, maybe GM is just feeding us a load of crap, who knows, the PI explains what GM claims the reason is for black smoke at startup.
Cold...? 84 deg is not cold...the temperature today late afternoon when my truck belched smoke like an old diesel on a "cold" start up... won't even address the gdi statement. .. Black smoke from any engine is unburnt fuel. . What does unburnt fuel do to cyl walls, 02 sensors and cats? Sure doesnt make them last longer does it?
Cold start does not relate to the ambient temperature. It relates to the engine temperature. If you park your truck at 6pm then let it sit all night and start it up at 6am, that is considered a cold start since them motor has cooled off.
Your V8 has twice as many cylinders as a Kia 4 banger. More displacement will result in more smoke. I had a 2012 Optima SX turbo and it would puff on start up. It would also puff after I gave it WOT.
Some of these responses are just a little bit silly, this is how ALL di vehicles work upon startup, this isn't something new. The Chevy 2.0 turbo engine does it, the 1.4 turbo does it, the 3.6 does it, the new C7 does it, the 3.5 ecoburst does it......see my point? It's a trait associated with direct injection engine upon startup, completely normal. There's no need for the worry warts to bother dealerships with this.
Obviously not..I have a 2013 Traverse with the DI 3.6... not one puff of black smoke... GM is feeding you guys a load of Bull.. and you're falling for it...
Overreaction maybe, but silly. Not really.
Given the extraordinary number of recalls on this redesigned engine, combined with an average cost of 40k.
This so called "normal condition" of DI engines is at least disappointing and at most embarrassing.
I had a couple of Fords that didn't puff black smoke and used a quart of oil every 2500 miles, it was called normal. My 14 puffs black smoke sometimes, uses no oil and does great on gas, Ill take the puff.
Most likely steam. Condensation builds up inside the exhaust after it sits, and when you start the motor, the heat vaporizes the condensation creating steam.
But if its HUGE billowing clouds of white smoke....then you have a bigger issue at hand.
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
