My new Denali with 34" Duratracs
Jon A
GREAT LOOKING TRUCK. GOING TO PUT THE 275/65/20 ON MINE. LOVE THE WAY THEY FILL THE FENDER WELLS
  • Replies 56
Stock (almost--airdam removed):
RC 2" front, 1" rear level kit installed (lower front shock spacer only + thicker rear block):
275/65R20 Goodyear Duratrac tires (34.1" OD):
Nice lookin truck ya got. I know you got a 2" level up front. What does the block physically measure out to be tho? Im just curious
The block is a hair over 1". And although it's called a 2" kit, I think it only raised the front around 1 3/4".
How hard was it to remove the air dam?? Want to do this but haven't had a chance to get under truck and look!!!
Any more pics. of the tires with more light on them? The pics. blend in with the wheel wells...Again they look BADASS!!!!!
Here are a few with a bit better light:
Yeah, it's easy, just a bit tedius. Unscrew the bolts...remove.
Now that you've had it for a bit are you still not noticing any rubbing? I'm thinking of going with your setup but I'm worried about the rubbing and if the tires will like too thin being that they are 34" and not even 11" inches wide.
Nice stance, appearance. I did the front level lift only, about a 1-1/2 under coil as I recall but do like what youVe done F&R in height and the 34" GY's. Any chance you can share some more photos directly from the Front & Rear. Also, what your experience has been since installing them in terms of turning/rubbing?
OK guys, here's an update. To recap, I have not done any trimming or anything else. I haven't done any serious offroading yet, so everything is subject to change in the future.
So far, I only think I've heard it rubbing once. I was on some sort of steep drivway with a large dip and had the wheel cranked. There is no visual evidence of rubbing anywhere. The spots it is closest are the inboard corners of the carpet liners--especially in the rear. I'll probably try zip-tying them out of the way a bit before doing any trimming. It seems possible to gain an inch or more of usable clearance that way without doing any cutting.
I don't think I've taken any from the rear. These aren't very good but they're the best I have from the front:
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,311 Guests (See full list)
