4WD issue
Yesterday as I was leaving work my truck wouldn't go out of 4wd, (I had it on auto) when I turned the knob to 2wd and 4wd off of auto nothing would change. I had a message pop up saying service 4wd. When I got home and turned the truck off and back on I had no issues? anybody else had any issues with 4wd on the new trucks?
Happened again today, would not come out of 4wd. Drove about 15 miles turned the truck off, went inside for 10 minutes came out and it switched out.... frustrating...
Take it to the dealer then.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
