Signal Problems
LarryE
Just got my 03 tails in and installed them on my 99...
Note: All the lights worked perfectly before installation.
All the lights checked out fine except the signal lights, they will not work now on either side OR the front, and even the indicator lights in the cluster will not light up
Note2: The hazard lights will still work.
From the tech manual on these trucks from what I can tell, the hazard and signals are on the same circuti, so shouldn't both not work.
I'm positive everything is plugged in tight on the power block under the bed, but I'm going to double check this evening (but if they wasn't none of the lights should work should they?)
I know someone here is smart enuff to help me figure this shiz out
true...   I'm gonna try new fuses this evening...  according to the Hayne's Manuals there is fuses for the signal  so that may do it   if not I'll go from there.
no one uses turn signals.  I thought newer cars didnt come equipped with them
If you really need signals roll down the window and use arm signals  :cheers:  :D
Things might not be quite the same between your '99 and the '03.  I saw a topic in the LD forum about how the wiring for an Electronic Brake Controller wasn't the same as last years trucks.  So maybe some of the other curcuits aren't identical either ???
for a 99:
Turn Signal lamps
When the ignition switch is in the run position and the turn/hazard switche is in a turn position, voltage is supplied from the TURN fuse through the turn/hazard switch to the turn/hazard flasher, CKT 1696. The flasher then passes current back to the turn/hazard switch in an intermittent on and off pattern, CKT 1697. From the turn/hazard switch, voltage is supplied to the LT TURN or the RT TURN fuse, CKT 14 or CKT 15. From the fuse voltage is supplied to the respective lamps on CKT 2114 left or CKT 2115 right.
Hazard Lamps
When the turn/hazard switch is in the hazard position, voltage is supplied from the HAZ LP fuse at all times through the turn/hazard switch to the turn/hazard flasher, CKT 1508. The flasher then passes current back to the turn/hazard switch in an intermittent on off pattern, CKT 1697. From the turn/hazard switch, voltage is supplied to the LT TURN and the RT TURN fuse, CKT 14 or CKT 15. From the fuse, voltage is supplied to the respective lamps on CKT 2114 left and CKT 2115 right.
after reading that i would say you blew teh TURN fuse :cheers:
nope nope and nope   :cheers:
there was dirt around the connector,  unhooked em all  cleaned the power block off and they work now
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
