There is a fix (reprogram) for UQ3 equipped trucks only.
I don't have the UQ3 I have UQA - BOSE AUDIO SYSTEM. I guess nothing else has come up on this. It is very load.
  • 8 months later...
I have uqa and I can adjust the volume in my settings
How can I tell if my truck is UQ3 or UQA?
There is a list of codes in your glove box
I had the radio reprogramming done to my 2015 this week. You could hardly notice any difference. Sort of a waste of time. If I would have known the outcome I wouldn't have bothered. Especially since it's an avoidable annoyance in the sense that you don't hear it if you buckle up first.
I have the volume setting also but it does not change it any lower.
  • 3 months later...
I've only had my '15 Silverado a day and that chime already drives me nuts. I haven't turned down the volume yet (learned about that here), but I can say it is WAY louder than the new Fords we have at work. There has to be SOMETHING that can be done. That chime covers more than just the seatbelt
  • 7 months later...
I have this same problem in my 2014 GMC Sierra.
I had the dealer take a look at it, after giving them the heads up on the bulletin. They performed the steps that were listed but it did not fix them problem. After looking at it a second day, they came back and said it is the 'amplifier' that is faulty, and it would cost $740 to replace. Since I have 40,000+ miles, it is no longer under warranty.
Like others have mentioned, the chime is associated with the seat belts, so buckling up before starting resolves that part of the issue. However, the loud chime also occurs for the proximity sensors. It is also an occasional loudness as well.
The problem isn't worth the $740 cost, so I suppose I will just deal with it for now.
I posted this in the other threads about this chime. Just buy one of these:
http://www.seatbeltextenderpros.com/chevrolet-silverado-seat-belt-extender/
Get the 3" rigid one in the color to match your interior. They are the only manufacturer that meets all the safety ratings. Leave it plugged in and the chime is gone (well the seatbelt part - it doesn't help with the other times but they don't happen too often).
I would have thought the 15s, 16s, or 17s would have corrected some of these customer reported nuisance items. You have to admit, the damn chime gets your attention and more often than not, gets you to put on the belt. :crackup:
  • 5 weeks later...
I have the uq3 truck. How do I get the reprogram? Does the dealer do it, is it free?
Anyone?
Responded in your other thread. The dealer does it. I don't have the TSB number handy but you need to ask about it. If your truck is out of warranty they will charge you the labor time to do it.
I saw the other thread, thanks man.
My dealer told me they would do the TSB for free for me since I just bought the truck. Anyone have a link where I can read about the TSB, I'm looking for the TSB number.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
