  • 9 months later...
On 8/15/2024 at 7:05 AM, Texasdeere said:
I appreciate the input.  It has been getting worse lately.  Now it is always loud every time.  It doesn't even step down like it used to.  It is so hot down here now I won't even get into my truck without rolling the windows down first.  Yesterday I had enough of it and unplugged the dash speaker.  Not having the turn signal tone will take some getting used to.  I don't hear high pitched or frequency sounds through my left ear so I may not notice the stereo sounding very different.
That being said, if I thought the dealer would be able to do something about it I would take it there and have the chime "programed out"  but I understand why they wouldn't.
There is one more thing I may try in the future.  I read this on another website but I have never seen anyone else try or confirm that it actually works but it does sound feasible.
From T and P on March 9th 2024 (Silverado Sierra Forums)
(If your chime volume control in the settings does not affect the volume, it's on lowest setting and still way too loud, your radio's amp is shot. These chimes are controlled through the amp. You need to remove the amp, note the part number and purchase a used one from Ebay. All of these other fixes are useless. The amp is mounted on the back cabin wall. To access you need to remove the larger half of the rear seat. It's an easy fix once you have the new amp. The rear seat is two sections, the short side and the long side. There are 2 10mm screws that hold the short and long section of seat frame together then about 5 nuts that hold the long section of seat frame to the floor. Remove these and lift the seat up and out toward the front, just enough to give you access to the rear wall of the cab. You will find the amp mounted on the wall right between where the two seats meet, covered by a layer of insulation. Unplug the old one, plug in the new one and then replace the seat. Your chime volume control will be restored.)
I know this is an old thread, but I didn't see any point in starting a new one.
My '15 Sierra just started doing this, to where it's randomly loud and then normal.  Did you ever do the amp fix that you posted about?  If so, did it work for you?  The post just below you mentioned "radio module," so I guess I'm kind of curious if one or the other (or both) can be the culprit.
I am just starting my research on this, and I typically don't use our dealer in town.  So I apologize for the additional questions.  Oh, and that post you quoted...Is T and P a user there?  Thanks.
T and P was on another Forum.  I don't know if he is on here or not.  Without any further information, as in the only one case where this claimed to fix it.  It wasn't enough for me to try it.
This isn't going to work for most people but for me it was the lesser of the two evils.  I disconnected my front left dash speaker.
For me the only real negative is you loose the Turn Signal Tone.  On the plus side I am not constantly aggravated and stressed.
With my compromised hearing (no high freq in the left ear) the radio sound difference is hardly noticeable.
The Radio module mentioned above sounds promising.  The re programing part is something I won't be able to do on my own.
Thanks for the information.
I've not been able to address this further just yet, as I'm dealing with another problem (tail light installation) that has taken priority.
I'll be looking to see if there is anything new about the radio update, but I'm gathering, based upon what I've read so far, that this might not work for me due to having the Bose system.  Thanks again.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
