I'm wanting to order my lift kit because my truck is supposed to arrive in a couple of weeks. The issue is, I need to know when ordering if I have aluminum of steel control arms/steering knuckles. I have searched and read every line of the standard equipment list and cannot come up with an answer.
Other than having the truck in front of you, is there a way to know based on options/packages/trim which one it will have? the dealer is useless for this info. According to the salesman they all have "metal". So i'm trying to find out if there is a way to know based on the specifics of what I ordered.
Anyone know?
What does a CC denali, 4wd, standard bed, 6.2, off road suspension package come with?
I can wait until the truck arrives to order the parts but I'd like to do it before if possible.
Or can I find out from GM with the vin? Any info appreciated.
Anyone know?
The off road suspension gets you the aluminum suspension. My double cab LTZ has the standard suspension and I have the steel control arms.
Yup stock z71 is aluminum. Not 100% what the denalis have though but I would guess they are aluminum. What kit are you looking to get?
Edited by Full Lock
I was getting the bds 4 most likely. After looking around that seems to fit best what I am looking for. They were very helpful on the phone an were specific about me knowing if I had alum or steel before ordering. Even offered to expedite shipping if I had to wait to have the truck in front of me to order it to lessen delays of getting it done.
At this point i'm not in so much of a hurry because I just heard back from magnuson and the kit is pushed back from April to "summer" so I have time I suppose since I wanted to do everything at once and be done.
Thanks for the replies. Much appreciated.
My Z71 is steel. I thought the alum verses steel was related to whether it is DC or CC?
There is a real easy way to tell. Look at it.
Its not a standard Z71 part, comes on the Z60 performance suspension (Denali etc)
My All Terrain Z71 double cab has steel control arms. I checked with a magnet.
I think Crew Cabs get the aluminum arms to reduce weight.
Edited by fondupot
My crew cab Z71 Standard bed has steel, so who knows!!
Steel on my crew cab Z71 standard bed also.
Aluminum is part of the Z60 pkg as elcamino pointed out above.
damn I just double checked mine and I could've swore I had aluminum lowers... maybe it was all the staring at the McGaughy's kit got me confused haha
does the Z60 only come on Denalis?
ok found some info. z60 is more of a on-road tuned suspension and the z71 is obviously off-road tuned.
info thread here
http://www.gm-trucks.com/forums/topic/156378-high-country-vs-ltz-z71/
Edited by Full Lock
My LTZ Z71 4x4 Silverado short bed crewcab has Aluminum. My LTZ Texas Edition 4x4 Silverado with short bed and crewcab has steel. I don't know about GMC since I did not look at them when I bought my Chevy's. Both have the 5.3 motor and 342 gearing.
Edited by bearman95
well I'm just totally confused then. Does your RPO have both Z60 and Z71?
My LT Texas Edition crew cab short bed 4x4 has steel control arms and knuckles. Who knows how they decided what got what lol.
So basically from what I'm reading the answer is that there is no definitive answer based on specifically optioned/configured vehicles?
My obvious last resort is to wait for arrival to determine. I was hoping there was a way to know in advance to save time in ordering but from what I can find (which is nothing specific) it is a crap shoot with regards to what you get.
That is ok. I appreciate the info. It appears to be one of those things that could be one way or the other and GMC/Chevy doesn't have any specific record of how/why something is done. I'm fine with it. I have so many other things to get that this will just have to wait until arrival. There are worse things that can happen. This one wont cause me to lose sleep. When it does arrive I'll certainly post what wound up being underneath it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
