With the reports I see, I'm going to check both sides to make sure they're both the same. I looked on one side today and the upper and lower were steel. March 2014 produced GMC crew AT 6 1/2 ft SLT 5.3L 4x4
Regarding availability of Z71 on the High Country, I noted that my GMC All Terrain package includes Z71.
Edited by spurshot
Waiting for mine too be built and show up before I order a leveling kit.
Anyone who has 4wd with Steel Upper control arms, and has removed them for a lift kit replacement or if you
Would just like to have Aluminum Upper control arms, Ill trade with you! I need a set of steel uppers to use
With Drop spindles, so let me know if u'd like to swap!
Btw, we all should have aluminum lower control arms, i think since '05 GM has used the lower Alum CA, in 07 in was on all 1500 chassis (truck/suv 2wd/4wd). Iirc
PLWTWO, the reason you'd need new control arms is because if you press the stock bushings out you won't be able to press the cam bushings in that come with the drop kit. Aluminum makes it a one time press fit and therefore non serviceable for bushing replacement. Which ordinarily wouldn't be a big deal since they are non serviceable ball joints anyway.
I wouldnt be pressing the cam bushings in or out of the CA, swapping the spindles, just the ball joint mount to the spindle (upper and lower), the balljoint would mount the same way to the spindle, with either CA. I was told its the force exorted on the Upper is higher then the aluminum control arm is
able to except safely. So its a lawsuit avoidance stance, Mcgaughy even saidthey'll fit perfectly with no issue, we just feel it isnt safe in the long run.
FWIW, my 2012 4wd, 2013 2wd and 2014 4wd all have steel upper & lower control arms.
My '13 Z71 has cast iron upper and lowers.
Wow, I guess GM doesn't hold conformity to close to heart. I stand corrected. Every one that has came thru my shop has had aluminum lowers... I currently own a '12 & a '13 and 2nd '14 all with aluminum lowers. Had '2 '05's, '07 and they had aluminum lowers. GM just doesn't make sense, no wonder they had cash flow issues.
Can you take a pic- haven't seen cast iron control arms.
No, they are the iron/steel ones that 75 percent of them have...
Edited by 2013sierrasle
Aluminum upper /lower and steering knuckles - denali 6.2l 4x4 with z71 option. Yes they are used to reduce overall weight(42lbs in total) for crew cabs at higher trim level and specific options
Im going up to the dealer in a few to look for myself since the truck arrived the other day. I will certainly provide whatever info I can get from my specific truck. Maybe at some point we will be able to determine the exact style/options that get which parts. The ppl. at bds were super cool. They were going to let me get one complete kit and then also get the other type of knuckles/arms so that when the truck arrived I'd have the parts I needed either way and I could return the ones I didn't need and not pay any fees or shipping charges. I figure that was more than fair offer. Only thing left to do is decide if I want the truck or not. I'm really soured by the way the incentives and pricing issue is being advertised. Spent 3 days trying to get straight answers and still unable to. Its to the point of principle. The plan is to go see the truck in person today. If they can explain to me all the details of advertised prices, incentives, etc. I'll buy the truck. If I don't get a good feeling from their explanation I'm going to say thank you for your time, and get something else. I don't like being treated like a fool. I especially don't like when someone tries to bait and switch me. If that's what I come away with I'm walking for sure. Either way. I'll check knuckles and arms before I do.
I have a CC LTZ Z71 standard bed with steel. I read the following in another forum. "Any time you have two dissimilar metals in contact with each other, there will be some degree of galvanic corrosion. (It's actually the principle that makes batteries work.)
The parts can end up 'welding' themselves together. (and yes, salt helps that process along) So that's why you always use an anti-seize compound when you put steel (or stainless) fasteners in to an aluminum part."
Edited by TX14Z71
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
