Open tailgate height?
If someone can take it for me, what's the measurement from ground to top of open tailgate for the 4x4 version? (I'd be getting an LTZ CC 6.2. max tow, but pretty sure all 4x4 versions are the same dimenisions heightwise). I have dogs jumping in/out all day, nearly everyday and want to compare to my old F150.
I cant measure very accurately right now, but later I can. But if I recall its just above my belt buckle. An dim 5' 11".
I just picked up my LTZ CC 6.2. max tow 4x4 Monday. I just went and measured and it is from the ground to the top of the open tail gate 35 1/4 inches on a flat surface.
Well this isn't very helpful at all! Suppose you wear your pants like Steve Urkel?
Or like diannabill wears 'em...
You musta been flying your drones awful low to get those shots. I better start paying more attention!
Awesome! Thanks for the quick response!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
