Dash light sensor...backwards??
Guys my new to me 2013 Silverado LT has a weird situation..When I turn the drl off with the light switch, it doesn't turn my dash lights off. I'm talking about the green backlight behind the Speedo etc. In fact, I literally can't turn it off. They stay green and lit all day....until night!! Then if I turn my lights off, the dash goes dark ! Just confirmed this today when in the car wash. Headlights off, dash lights on before going in, and sure enough dash lights turn off as soon as I got inside and it got dark.
Is this a simple wiring or fuse being backwards or is there something else at play here....am I an idiot and just can't figure out how to turn them off??
Hey grafik,
I’m sorry to hear that you have a concern with your dash light sensor. I am not properly trained to offer technical advice, but I will be glad to look further into this for you. Please send us a private message referencing this thread if we can be of any extra assistance. Thank you.
Kristen A.
GM Customer Care
It's designed that way
To be lit during the day and unlit at night? I am almost positive it was the opposite on my 07 I don't see why they changed it?
Silly question but is your brightness knob turned all the way down or something?
You don't have something laying on top of your sun sensor do you? The dash lights shouldn't be on in bright sun with the headlights set to auto.
I've turned my brightness knob up and down to no avail.
Where's the sun sensor? That sounds more like the culprit. But why would it go dim at night then tho
I actually tested putting something on top of my light sensor --- the dash lights turn off. Makes no sense why it would be dark in the dark and lit in the light. It must be backwards.
I called my stealership and the service guy tried to convince me that it was functioning properly, and that there was NO WAY I could turn my dashboard lights off.
So I opened my manual, and on page 6-3 I read "When your DRL system is on, the taillights, parking lights, and instrumental cluster lights should all be off"
I'm going to bring it there with the book and have them explain to me how the manual is wrong I guesspost-129671-0-78069100-1397776316_thumb.jpg
Normal. Mine is exactly the same. There is no way to kill the backlight during the day.
  • 6 months later...
Think I am having same issue. Battery in truck died while I was deployed, partner did not start it like I asked!! But ever since then, my dash lights work in the day but go out at night. Like he said in the beginning, seems like it is backwards. Yes, tried the dimmer knob, yes replaced the whole switch, same issue.
We're sorry to hear that you're also experiencing this concern, BLucas11. Please let us know if there's anything that we can do to help out with this matter. If our help is needed feel free to send us a private message in reference to this thread. We look forward to hearing from you!
Kristen A.
GM Customer Care
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
