New headlights
Old ones were hazy, and the passenger side one had the bottom tab broken off that helps hold it still.
Aftermarket?
Aftermarket?
Yea, I bought them from Rock Auto. I bought the same brand of driving/parking light lenses last May, and haven't had any issues with them so I figured I'd try the headlights.
Got a question for ya. Did you have a strong gas odor coming from your exhaust before you fixed the evap canister? I do and I think it may be the culprit
If you need fogs for the truck I found some on Amazon for like 25 for the set of two. Some people gave them low ratings due to fogging, but I or a bread of clear silicone around them and haven't had any problems.
Didn't notice any gas odor. It could have been there, but I don't remember smelling it.
No fogs yet. They are actually in good shape. Do you have a link to them though? I could bookmark them. Edited by Daryl Z71
Didn't you have the gas odor when you had the exhaust manifold leak? Prior to the clamp things being installed.
I still have 2-3 broken bolts but the gas odor is only present when its hot out, so far this winter I haven't noticed it as far as I can recall. :/
Edited by white1500
Might have... I had an odor before I installed the clamps, but I just thought it was exhaust.
I'll find the ones I got and post the link for you.
Those ones are different then mine. Mine are the larger ones that weren't started until 2003. They probably sell those too though.
Ahh I figured the trucks and suvs used the same.
They did, but 2002 was the last year they shared them.
SUV uses the same as 99-02 trucks.
Installed new headlights today. Also put Silverstar's in the high beams, already have them in the low beams and fogs.
New Housing:
Old Housing:
Edited by Daryl Z71
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
