If you could get the wiring schematic from kicker I can see where it wouldn't be hard to add a sub. The one good thing about the amp/crossover setup is the highs/mids sound much better up front. Don't get me wrong when some hard hitting bass tunes come on it does sound good.
I was very seriously thinking about getting that Kicker. But I ended up getting my audio shop to do a little custom set up.. basically the same idea, but with better stuff. Total costs of my set up was about $850 and it is worth every penny. This BOSE system really comes to life with a sub.
I got a JL 10TW3, custom fab box for double cab.. JL AMP, base control knob.
If I had the Bose,I would have went to a custom shop for a sub. But the base stereo is seriously lacking volume and clarity.
  • 5 weeks later...
I'm thinking about selling the sub portion of my kicker setup. Just not enough bump for my taste. Love the high/mids up front.
No,the front amp/crossover and a self powered sub have separate power leads. They can be separated if you already have the bose system.
No bose system here, just the stock shity system.
I wish they offered just the front option. Sounds really clean. So I could add my own sub.
Trying to decide if I wanna buy this kicker upgrade. I found it for $599 at a dealer, trying to get rid of the last few they have...knocking my head on it lol.
Come to Savannah and buy mine for $500 I'll help you install it after you hear it in mine.
Just wondering if anyone bought just the sub enclosure setup and if they still have their directions lying around. I need to know which colored wires to slice into behind the front left kicker panel. Thanks
I believe Crutchfield has a how-to video that you can use for the install. The sub by itself is only like 527.00 linked to price. The video link from Crutchfield is LINK. I still cant decide if I want to pay the $850.00 for the full upgrade.
Dude, I LOVE my Kicker upgrade. especially at 599 thats a steal. just make sure it also comes with the amp and processor for the highs or thats not a deal. if its just the sub I wouldnt have been happy with it.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
