This thing likes to be pretty close to flat on the eq.. I bump up my highs just a little because im an old stereo junky and my ears arent what they used to be "little hearin damage" lol
Having owned all the different versions of the Chevy Silverado going back to 1987, I think their is a difference in the factory radios. On the 2014 you have a lot more to play with to tailor the sound. I could not image this set-up on my last two series of trucks. (2009 & 2003). Instead I had some serious equipment in both. I would love to just have some pre-amp outputs for highs, mids & lows and then add my own amps with this front-end. It can be done, but price, return to stock ability and just plain getting older..... I don't need it as much any more. I actually still have a lot of the equipment and speakers and may try updating the speakers. I have a set of ZR series JL Audio speakers and a set of German made MB Quart QSD216 speakers. We'll see in the future.
Edited by krdeal
Well, good thing is, most web places discount it. Of course, they just came out with them "officially" so it may take a bit. I am even more fortunate as I can get it for a WHOLE lot cheaper from Kicker due to working for a company that sells their products.
Yep, pretty much. Kicker did not sell them till they showed them at CES. GM I guess had a lock on it for a bit. It was just put on Kicker's site last week.
Hmm, idk then, maybe I am mistaken. I swore I looked for it on their website last month and they were not there. I know for a fact they were not in the accommodation system until last week.
Ahh, now it makes sense. You had me thinking I was losing my mind. Mine will be here on Friday. Probably will not get to it until Monday though.
I got mine installed yesterday! It is perfect! I got it for $869. shipped. Hard to beat for the price.
Hey LaVaDog did you get just the sub setup or the whole upgrade kit and where did you get it?
