You dont splice into any part of the sound system with this upgrade it is 100% plug and play... other than hooking up the power wires.
The sub only kit does require you to splice into your speakers wires. I should know, they sent me this kit by mistake before sending me the full kit with is truly a plug-n-play system. I should have paid more attention to the directions that came with it. The splice connectors looked just like these...
sorry to necro this thread- would the kicker 400 upgrade (200w speaker amp, 200w sub amp, and sub) work with a 2014 crew cab all star edition w/adjustable pedals? The product description says it wont, but... I'm curious. If anyone has this setup, please let me know! Thanks!
Hmm... I've read that the location where you mount the dsp amp is taken up by the adjustable pedals... Can anyone confirm this? Or, even better, has anyone with adjustable pedals installed the 400 system? Still unsure as to why I wouldnt be able to simply relocate it... Thanks in advance!
2014Mallcrawler did. Read about 3 pages back in this thread.
Just do it.. you'll love it. best part is you wont need to put in different speakers either... I can run almost max volume and its significantly louder/cleaner/more bass than stock and doesnt distort out.
if youre used to the thump of 2 12's and super bright highs and punchy mid range this wont be for you. but if you're wanting the best $900 warranty keeping sound upgrade that really rocks the house for stock then this is your animal. Get ready to readjust your EQ. Id put it all to flat before doing the install so you can be most impressed with the initial turn on.
Video won't do anything... you can't feel the bass with a video. I'm sure the speaker kicks well. But I also think ( as covered before) that for about same price you can have a BETTER set up custom built - like I did.
I like the fact that the kicker is made for our trucks.. but my custom box fits like a glove as well.
Installed the 200/400 system over the weekend. Here is my opinion, it was easy to install, but i would expect a few hours. My kit was missing the instuctions for the front amp but it was pretty self explanitory once i figured exactly where the amp went and how to get the dash apart to attach the jumper harness. It is 100% plug and play with the 200/400, no splicing :). I would give it an 8 out of 10 for sound, it definitly filled out the sound. The door and dash speakers do sound better and the bass is pretty good for what it is. The system as a whole met my expectations, although i do think it is a little over priced, this should scratch most peoples itch for a little more in the audio dept. I will still probably upgrade to a custom system someday but that definitly won't be anytime soon....
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
