5.3 or 6.2 - Do you wish you would have gotten the other engine?
14DENALI
I feel sorry for the folks that got the 5.3.
Why would you feel sorry? I feel sorry for you that you feel sorry for me. LOL
  • Replies 45
IMO....get the 6.2. I am averaging 18.2 MPG for the first 2K miles and can't wipe the smile off my face when I drive this thing. The truck has two personalities really. If you want to take it easy and hypermile it you can get great MPG for a big truck, or if you want to just have a little fun with the loud pedal it will make you grin like your 16 again in dads truck. If you do any kind of towing these trucks shine even more. The only downside to the 6.2 is the 10-15% more it costs you to run premium....well that and the $2K buy in price. I knew I wanted the 6.2 and just ordered it because I knew if I didn't I would always "want" what I knew I should have bought in the first place. Do it right the first time :driving:
x1000
No way I'd go back to a 5.3 after owning this truck.
you have to ask yourself do you need the 6.2 for towing or do you need to win a manhood competition. if you find yourself buying it just because its bigger and better, dont waste the money. i will admit i bought mine simply to win manhood competitions. i'll never tow with the thing, and drive it like a grandma 95% of the time. i just dont like to be one upped when someone tells me they have a 5.6L
The only thing im jealous about the 6.2 is that it doesnt have 4 cylinder shut down, otherwise im very happy with the new 5.3
My 6.2 DOES have AFM... it does shut down 4 cylinders just like my recent 5.3 does. I like 'em both.
I have the 5.3 and am happy w/ it. This is the nicest truck/vehicle I've owned and has performed flawlessly for me for 17,000 miles and counting thus far. I DID swap the original 5.3/3.08 geared 2014 I had because I realized I needed the 3.42 if I ever wanted to tow, it makes a .6 difference 0-60, and I got the AT package which I really like the rims/interior. I don't care about having the most powerful motor in a truck that I'm not using specifically for work/towing all the time, I just need the space and 4x4 and higher suspension vs. a car because I'm in the scrap metal/demo business. 5.3 or 6.2 - neither truck is "fast" the power is adequate in either so long as you get the 3.42 or 3.73 rear end.
I will add one caveat though - I also own a Z06 and that more than satisfies my speed fix, it also makes anything south of an M5 feel "slow" - including ANY stock truck. If you can only have one vehicle and really care about the power and only want a 1/2 ton then I guess opt for the 6.2
The reason I quoted the above is to LOL a little - not to be a dink, but if you really wanted manhood/bragging rights you should have bought a REAL truck, meaning an HD, because the difference between a Tacoma and our trucks is probably less than the difference between an F350 turbo diesel and a 1/2 ton. I mean it literally is that big a difference.
If you want a "real truck" w/ "real power" then get one - 2015 SIerra 3500 w/ the allison tranny, I say go for the Denali package while you're at it (I heard it adds at leas 1/2" of "manhood")
100% agree. I'm in love with my 6.2, smile every time I drive it. :)
I wouldn't own another 5.3 so this time I bought a 6.2. Do you have to run premium fuel? I've only had mine for 2 weeks, nothing was ever mentioned about that to me?
Aczr2k
As gm says with there cars ( Camaro and corvette )
You can run 87 but you won't get the power and performance u paid for. If u got the 6.2 put 93/91 octane In it
I sold my lifted 2014 with the 6.2 and bought a 2014 AT with the 5.3.... I like this just truck just as much and I don't HAVE TO use premium fuel. I don't haul anything and my commute is mostly highway, so it was a no brainer to me.
Yes, it says on the inside of the fuel door you need to run premium.
my bad, i thought the new ones still didnt have it. not jealous anymore haha
I was hoping I could help conserve your jealousy! :thumbs:
It says inside my fuel door "PREMIUM FUEL RECOMMENDED".
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
