I'm getting a clunk from the rear end of the vehicle when I let off the gas then reapply the gas. Very annoying. The vehicle only has 320 miles on it...
You're not alone, as you can see by reading a bit here. I took my truck into the dealer for the rear end noise, and was given a copy of TSB #01-07-30-042H, which was originally issued in 1/14. Basically just GM's way of giving the service techs a way to "explain away" the noise as normal.
I'm taking my truck to a different Chevy dealer service department on Friday, to have the rear end noise checked again, as well as the issue of my drivers seat "clicking & shifting" in corners. There are two TSB's covering this issue, so I'm hoping they can resolve that one.
I'll report back here on the outcome. Cheers - Rick
No go on the axle shafts fixing the noise though it did seem to help a little for the first few days. Really does it when I'm backing into a parking spot with the wheel turned. Back to the dealership again next week (3rd time for this). I have a laundry list of issues on this truck now to go along with the rear end noise:
1. Exhaust valve squeaking like crazy whenever I hit the gas. Dealer said you either get one that squeaks or one that shakes. Good to know.
2. There is a really bad squeak in the front end whenever I hit any small bump in the road. Sounds like a plastic on plastic squeak.
3. Noticed last week there is a rattle in the dash just above the head light knob. If I tap on the dash there is a rattle/vibration.
4. I also get a nice creaking sound whenever someone gets out of the truck. If I grab the bed and rock the truck back and forth I can replicate the sound.
5. On the drivers side there are tons of little paint imperfections.
6. Onstar randomly activates and then ends the call without actually calling out.
7. Rear camera goes out about once per month. Have to shut it down, let it sit for a minute and then restart before it will work. I can't get it to repeat so the dealership won't do anything.
8. A/C randomly goes into recirculate. Dealer said this is normal.
My 1 1/2 year old truck sounds more like a 10 year old truck with all the noises it makes. I like the truck but all these little problems are getting ridiculous.
After reading all this b.s I'm really hoping that this can be corrected. If I bought a brand new 44k$ truck and it's going to do this forever it's unacceptable. To be honest at 5k miles and I'm already having issues that's just b.s too. If it's not a quick fix I'll never buy one again
You are pretty much describing the ride in a 1997 U haul F350 rental box truck with 230k miles on the clock. I drove a decommissioned one recently that was offered for sale. It had its share of squeaks, rattles, creaks, and annoying whistling wind noise through the door seals. And a bunch of dings and dents all over. But it was offered for $ 1,800 and it had the old 460 cu in V8 workhorse under the hood.
Edited by pm26
  • 2 months later...
I have same issue but waiting on gm engineer they replaced parts in transfer case and diff carrier incorrect shimming at 11000 km now month later clunking again shop foreman n mechanic say transfer case needs replaced but they just replaced parts a month ago loud clunking but I tested this in manual n I cannot here the clunk as soon as I put in automatic from manual boom clunking instant
Today, 07:42 PM
Hi I'm new to site but read post that seem similar to me I hit 11000 km and all of sudden loud clunking. Took to dealer they found rear gear oil black with mettalica fined replaced rear diff carrier due to incorrect shimming they also replaced parts in transfer case.noise was gone 1 month later clunk is back louder and now to when I Rev up to about 90 km and let off clunk occurs again .need suggestions and help shop foreman n mechanic think to replace whole transfer case but are waitin to here back from gm engineer? ?help
  • 4 weeks later...
i get the same clunk at any speeds when letting off or on the throttle has def gotten worse use to only be slow speeds between 2-3 but now its all the time and sometime it's enough to make anyone in the truck lunge foreword.
I've had the same issue with my 2013 Silverado. I have an open case with the BBB and am trying to get this issue resolved at this time.
If you haven't made a claim with the Better Business Bureau, then please do. You can find you local representative at http://www.bbb.org/BBB-Locator/. They are extremely helpful at the BBB and filing a claim is pretty simple.
Please take the time and go through the process of submitting a claim. Hopefully it helps everyone with these defective vehicles.
I have a 2014 and my was doing the same clunking sound. I had read something in one of the forums that this was a rear spring issue ( not matching) . I took my truck to my dealer and ask to speak with the shop manager and explained to him my issue., he directed me to his shop foreman and we took a test drive ( not a long one ) he told me that their have had other trucks with the same issue and that there was an order to try to make the clunking disappear.
1: tighten everything and grease the springs
( if that doesn't correct issue)
2: change brackets and (rubber half ball on spring)
3: order new springs
Well the shop foreman said he wasn't going to make me take my truck back 3 times for the same issue and skipped to step 3 ordering me new matching set of springs.... This fixed the issue and I have not heard a single clunk
Edited by superchuck
They have replaced whole transfer case . No noise what so ever .seems the clunk is same but abit different as to what the cause is but all explain clunk occurs when u acclerate then let off gas.
  • 2 months later...
I'm getting a clunk from the rear end of the vehicle when I let off the gas then reapply the gas. Very annoying. My Midnight 6.2L only has 1320 miles on it...
I almost feel like something is going to explode after my warranty expires..
What should a do? GM... ding dong..
I get the same thing ... same behaviour. It's not super loud though.
    250.3k
    BryantM4
    BryantM4
  • Who's Online   4 Members, 0 Anonymous, 759 Guests (See full list)
