guys who did muffler delete are u happy with sound ?
Why do some people wire them open ?
People do it with stock exhaust to try to get a little more sound out of it and as the valve gets older there have been people that have problems with them making noise
  • 2 years later...
  • Replies 31
I can agree with this. On cold startups my truck was squeaking and making annoying sounds that a truck with 9000 miles should never make. I used a hose clamp to hold the flapper fully open and all of that went away. Also a lot better sounding exhaust note with the valve open. Unfortunately there is some drone in v4 mode but I can live with it.
Did anyone lose fuel mileage after deleting muffler and flapper valve? Does any of this keep the afm from working correctly?
no and no. I cut the exhaust off at the muffler and welded in a dynomax bullet dumped with a tip. The whole setup cost me $300 with all stainless parts and pipe with install and I couldn't be happier
You added a muffler though I just had straight pipe put in place of the muffler and flapper valve. So would that effect gas mileage or the afm?
a bullet isn't a muffler, more of a resonator
Iv deleted my muffler and my resonator and tuned with Diablo sport and I like it.. Yes it's loud, yes it's loud on cold starts, yes it sounds like a truck now, no my mpg didn't drop, will it drone on the hwy yes a little but with music it don't bother me and in v4 it's a bit loud but I can live with it
Sent from my SM-G930W8 using Tapatalk
  • 1 year later...
1 hour ago, Robertof said:
I AM THINKING OF DOING THIS TO MY 2017 SILVERADO, has anyone done it to a 17 ?
14-17 is the same thing   it wont matter
I left the resonator but if I delete that too is it louder?
 Have been looking for a muffler delete pipe, it needs to be 3" x 27" long with a 2" offset and I haven't found one yet.
Nothing from auto anything , or Summit,  or even on E-bay. Has anyone else found a supplier?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
