Upgraded Shocks for 2500HD
I am looking to replace the shocks on my Silverado 2500HD with upgraded shocks to better handle towing a 16k Fifth Wheel trailer. I am getting way too much loping up and down on the bad spots on the Interstates.
Past experience with both Bilsteins and Ranchos on other HD trucks (and motorhomes) has shown that serious shocks can make a major difference in how well the truck handles extreme situations.
I am just starting the search for these so anyone that has already done it, please pass on some help!
Jack
After lots of internet research, contact with the Chevy dealer, and two calls to Bilstein I was able to pin down that the same shocks for the 2014 2500s will fit the 2015s. The Bilsteins for this application are #24-196437 Front, and #24-196444 Rear.
They also make other variations for 2500s that have had lift kits installed.
  • 3 weeks later...
can't go wrong with bilstein! After 200,000 miles on my ol GMT400 the factory bilsteins still rebounded and dampened when I was swapping them out for new ones.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
