Here are my overdue pics
Haven't put it on yet, looks so nice clean and unbeaten (also note I finally have a year that matches my tin sign I have had since my 69!
Looks better in person, not sure why the flash gave it a brownish hue, if you have ever driven a 4th that have funky steering wheel contours, this took 2 hours to put on(had the thread break a few times.) fxwV4Lu.jpg
Edited by SnakeEyes
So did you challenge or just sit and look pretty? I need to get this thing a little more presentable so I can start going to stuff like that.
I wasn't racing. Just hanging out at the open house Raymond's put on at his new shop. The tracks frown upon convertibles being on the track next car will be a coupe.
SCCA autocross! I would have taken mine last week but the rear seal oil leak could have damaged the clutch.
Speaking of, the oil pan leak still hasn't leaked a drop. It's obvious there is some running down, but two days and not a drop on the ground, I can wait a while.
13244117_10106351425698918_530152606163713235227_10106351477500108_406826497222713246281_10106351431761768_767863162292713239043_10106351429206888_2767937831413
13221611_10106351431866558_6555611428954
13268505_10106351430239818_8480213193203
13263920_10106351494216608_3004181882093
13198490_10106351494466108_844766604981113243729_10106351494326388_1083616769992
Edited by RyanbabZ71
Really hope they offer a limited pace car edition of the 50th.
Nope they only made two white ones. Al Oppenhauser was at the luncheon and gave the story on it. Ed wellburn was worried the gray 50th wouldn't look good in photos so they made the one (really 2) in a custom white (Cadillac color). No camaro said will be produced in this color.
Shows exactly how stupid they are, they know the 50th doesn't look like a celebration model yet are still selling it. Old GM has RETURNED!
GM has a HORRIBLE track record for pace car/anniversary models since the 70s. The bright purple C5 with bright yellow wheels, The 2016 Corolla and Camry "special editions" are more "special" and have a theme that makes more sense. That's pathetic. Two corvettes(not even mentioning the C4 and C5 pace cars were both purple!) and now two Camaros have been copies, IN a ROW!
Edited by SnakeEyes
Drove to work and then to urgent care with the family. One of the twins slammed his finger in a closet door(playing hide and seek or something) so I let him pick the car to take. He loves the "Flag Car"(either from the Camaro emblem, or the American flag plate on it currently). I asked him why he loves it so much, and he said "cause it's got the Chevy picture"(bowtie).
Oh my.
Started the oil pan project. Idiot that I am, I decided to put it in the third bay so it's out of the way if the fix takes extended time. But it's two feet shorter so I ended up taking an hour to jack it up, having to cram the massive low profile truck grade jack(I just gave away my small racing jack ironically) in tight spaces at odd angles. And then, for some stupid reason, the is a cut out near a jack point you can't see from the side of the car, the same width as the top of a jack stand. Bad design. Luckily I caught it before anything real bad happened, just a little bent metal on the rail cutout.
Edited by SnakeEyes
You know, you can get any car painted any color with a order big enough(fleet order). Group buy time!
Edited by SnakeEyes
Great pics.
I started on the oil pan from hades project. Wheels off, Got the Alternator out(and belt)/, lower strut towers unbolted, sway brackets unbolted, oil and filter drained, airbox and resonator removed(need to upgrade now, a seal in broken in the lid, so either need new foam tape or better option, upgrade to a fast toys 100mm lid for future upgrades) unbolted the steering shaft joint but couldn't get it to move, put the bolt back because a few guys didn't mention they had to do anything with it.
Maybe remove starter later If I have to and try to break the K member bolts loose.
Decided to order energy suspension engine mounts and do those(if they get here in time)while I'm there. If they get here by the weekend, they go in, if not, might just wait unless these are shot
Edited by SnakeEyes
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
