I am curious, what about your truck, how is it getting better?
My transmission shift changes have gotten longer between shifts. Wrong thread to have a conversation about it, I'll send you a PM.
Edited by The Zip
Since you mentioned the roof bow "fix"
Think 2 people here had it done only to have the bows come undone shortly thereafter
More recent posters have reported that dealers now say they are waiting for a solution from GM, so seems like GM "pulled" the roof bow repair and (hopefully) are trying to find a permanent solution
If some people are more sensitive than others to these issues, I'm curious if those who've noticed it have ever driven in one that doesn't do it? I drove probably 10 Tahoes and Yukons before I bought the one I own, which is the only one that didn't exhibit the really obnoxious noises. It still booms (flick a woofer) at low speed but that seems inherit in all of them.
Edited by cltsig
I'm still trying
I test drove around 10 before getting mine, same thing found the one where booming was the least
I've now been in about 30-40 between the 6 variants, and I have felt the boom in every single one
6 dampers on my exhaust fixed the 'flick a woofer' booming at low speeds.
Admittedly, I haven't spent too much time under the truck, but I don't believe our trucks have any exhaust dampers from the factory. 6 dampers were added to mine and the low speed booming over gravel roads, snow covered roads and other small bumps is gone. No part numbers were provided on my invoice.
Buffeting was fixed by getting wheels/tires under 15lbs RFB.
Vibrating was fixed with a rear-axle replacement. Mine was mild compared to some of the videos from our pickup cousins.
I just rolled over 30,000km [~18,000 miles] and really enjoy the Yukon. It took some effort to get this point, but it was worth it.
I saw your earlier post but couldn't quite make out the dampers. Was this something the stealership whipped up? Could it be DIY? I'd love to eliminate the booming. I think the first step is to rid myself of those made-from-stone Continental tires.
Edited by cltsig
Are you saying the pick up trucks have these problems? I was going to give up on the Yukon xl and go with a 2500 HD. Do they also have a lot of the same problems? thanks.
Very interested in hearing more about these 6 exhaust dampeners. Any more info and or pictures? Where was the dealer that did this?
This last week was out in the middle of nowhere in Arizona by Kingman. Running 80-90 mph. The truck has a BAD vibration at this speed that I've never noticed at normal 60-70 mph. Has to be something to the Buffeting on the freeway.
I'm at my wits end. Almost ready to spend stupid money for a out dated 2016 Landcruiser. Just to get rid of all these cabin sounds.
Edited by TOBTEK
The GM field engineer installed them at my dealership, just outside Toronto. Other than "install 6 exhaust dampers", there are no other details or part numbers on my invoice. I'll try to snap some pictures, though I don't have access to a lift and my Yukon is out of town for a few days.
To be clear, the dampers fixed the "booming" noise experienced when driving slowly over gravel or snow roads and other bumps. I once believed that "booming" was related to the "buffeting", but it wasn't, at least in my case.
booming: fixed by adding 6 exhaust dampers
buffeting: fixed by getting each tire under 15 lbs RF [i did this twice; factory Conti's and my snow duty ATs]
vibrating: fixed with a rear axle replacement
The Yukon has been super smooth, right up to 100mph ever since the work was completed in March.
@John: I believe all these issues are specific to the 1/2 ton trucks only. This is based on reading nearly every discussion on the matter and the survey results that I've been compiling. I'd triple check before making a move.
I've always agreed the booming and buffeting are two separate issues. I've been dealing with this MESS since Sept 2014.
Like to fix this Escalade for its the best looking SUV available IMPO, but looking for a suitable replacement asap. The 2017 Landcruiser is going to be even uglier then it already is :( the infinity is terrible, rover isn't the answer for reliability concerns.
Wish GM would just fix this problem so we could enjoy the vehicles we paid good money in good faith for.
Edited by TOBTEK
If you have the invoice I'd like to see the part number for the rear axle or the dealer you used maybe they can guide my dealer on what to do Edited by Lift
QTY FP-NUMBER DESCRIPTION
1 23360970 AXLE 053860
It was shipped in a wooden crate - I saw it on the shop floor when I dropped my Yukon off. Looking at the work order, I've put on just over 15,000km since it was installed.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,872 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
