I've been holding out on buying this truck for months now waiting for a fix.
I know your hopes are there will be a fix and it may be in 5 or so years when GM rolls out a new generation. But with this generation, a dealer is not going to be able to do anything with body, tranny, and engine mounts. Or length, cabin volume, and metal density. Until that time, the answer will be for dealers to make an extremely annoying level of issues to a less annoying level. A dealer may play with dynamat, tires, wheels, drivetrain, and maybe different suspension items to achieve a less annoying level, but you're going to be holding out for a long time waiting on a fix. A fix is way too costly, complicated, and restrictive for an independent dealer.
Edited by The Zip
CI Houn – My comment seem hopeless, but I say all this because I have read every page and posted on the thread beginning at page one, so I am basing my comments on customer data. I had my Tahoe LT for about 19 months with no dealership downtime and it has always been and continue to drive like butter, so there “is” some hope.
Zip does yours have the issue also?
My truck really is like butter. Having my truck for 21 months (not 19 as stated above), I have never had any shaking, buffeting, vibration, or pressure. Now I did start another thread on pressure, but I think my issue was associated with my particular setup and the XM signal. My fix was as simple as not using those XM channels.
Now there are standard size trucks having issues, but my truck is standard size, Chevy 2013 build cause it was on the road to the dealer in Jan 2014, 20 inch aluminum wheels, no roof rails, no sunroof, no under carriage engine debris protection (similar to a skid plate). I have all options of the LTZ except I have fixed side steps, no Magnetic Ride suspension, no rear entertainment, and no second row captains. Can these issues happen with my truck, yes, because Chevy/GMC/Cadillac all use the same GM platform.
Now reverse what I said for "maximum" issues; XL size, non Chevy 2014 or later build, larger than 20 inch wheels may not be aluminum, roof rails, sunroof, undercarriage protection, moveable side steps, Magnetic Ride suspension, rear entertainment, second row captains. Not scientific but I'm not a GM engineer, the data on this thread (give or take a couple of items) leads to the GMC XL version to include Denali with Magnetic Ride suspension and 22 inch wheels as the truck with the most customer complaints associated with this thread.
I will say though I have not heard “any” complaints from owners of the least expensive of the GM fullsize SUVs, the Tahoe LS. Go figure…
I will say though I have not heard any complaints from owners of the least expensive of the GM fullsize SUVs, the Tahoe LS. Go figure
I had an loaner the first time my truck was in the shop (SLE about as base as you could get) and the buffeting issues were worse in that than they are in my '16 XL Denali w/22" wheels.
First time poster here. I have 850 miles on my 2015i Yukon XL SLT and first noticed the pressure / booming at about 200 miles. Mine only seems to have it from 40-45 MPH, though it does have an annoying highway vibration as well. Fortunately no pressure at those speeds. Taking it into my dealer this coming week and have already forwarded them this thread. The service manager said this is the first one they've had in for the issue, but said he is willing to try anything to make it right.
Frank, can you PM me or post the info for your dealer that was able to fix your vehicle? I would like to get them talking if possible.
What a PIA for a brand new $70k vehicle.
My dealer is Quality Chevrolet in Escondido CA.
As others have mentioned, it is imperative all bows are attached to the roof. Crossbars / surf racks are not a bad idea to disrupt air flow but the roof can react to bumps and wavy pavement.
Frank
Don’t remember if any “owners” spoke about the GMC, but...
I am going full aftermarket (smaller) wheels and (bigger) tires plus more sturdy front/rear sway bars
Rethinking the sway, wouldn't a stiffer suspension make the buffeting worse? My initial thought was it would tighten it up so (hopefully) minimizing what's transmitted to the body
Thoughts?
My Yukon Denali [it buffets and booms] is somewhere in the middle.
  • short wheel base
  • no sunroof
  • standard 20" wheels
  • 2nd row bench
  • no dvd
  • has magnetic suspension
  • 6.2L/8A/3.23's
It's worth noting that people should open a ticket with their dealerships. If this problem is as widespread as it is, this is the best hope of a timely resolution!
The Zip I believe your intentions are well placed BUT, you have made 165 plus posts.
Some good most are discussing the same post over and over or your opinion.
You don’t own one of the vehicles affected and are interpreting, clarifying the posts and expressing your opinion to a point that it might be better to allow the owners to process the information and resolve this problem
The people involved are well educated and doing a great job and are able to understand the post without your re explanations or suggestions.
Your Post 1063 My truck doesn't experience anything associated with this thread.
This forum doesn’t need a self appointed moderator.
Your post 701 Let’s get the thread back on point. I agreed my posts can be shorter, so if I can help (even if it’s just one person) and I need to say it in longer than 4 lines or so, I’ll send you a private message. At the end of the day, everyone will ultimately do what's in their best interest, regardless of what's posted.
If you make a brief comment based on fact not your opinion, and follow your own advice above it would be appreciated.
I have also followed this thread and read all of the posts. This is my first post as I am on the sidelines and appreciate the information provided by the Owners affected with the issues and feel for the pain they are going through. I would like to purchase a Yukon but not till these issues are resolved.
Thank you to all involved.
Lockwasher
Thoughts?
It is very hard to predict these results. It could very well help on one stretch of road only to hurt on another.
If you have the booming, the Dynamat will help with that higher frequency noise. I don't think the Dynamat can help with the buffeting because that frequency is way too low.
I would say check to see if your roof is fastened to the bows and if not get that fixed first.
Frank
Lockwasher - You are on the sidelines and appreciate the information provided by the owners affected with the issues and feel for the pain they are going through. I am an owner not on the sidelines and my posting won’t be defined whether or not my truck is broken. I too feel the pain, you had to have seen that in one of those 165 plus posts. But, shouldn’t it be encouraging to an owner and prospective owner like yourself that I have the same truck in theory and it does not experience the issues associated with this thread?
Hey, point taken!
I had my Yukon XL SLT at the dealer on Friday and the engineer didn't even bother driving it as he was fully aware of the issue. He told my dealer to schedule the service to be done at their body shop and to do the roof bow TSB. He agreed that many times fixing just one bow will not fix it and he claimed that they have had luck getting rid of the buffeting in many cases.
My dealer is fully aware to reattach all bows at a minimum and if possible add additional support to all of them even if they are all attached. Additionally, it sounds as if GM will give approval to add sound dampener as well. I didn't purchase the vehicle from this dealer and I must say they are almost as interested in getting this fixed as I am which is promising.
The dealer wants to reach out to Frank's dealer in Cali and get a detailed list of what they did as t hey too only want to pull the headliner one time.
I am also going to swap out the 22 with 20" wheels.
I will update once the work is completed.
I agree with zip, It's good to hear from people who don't have this issue also to compare why some have it and some don't, what's the difference, if it happened on letter production maybe they used cheaper sheet metal or cut done cornered somewhere or different manufacturer parts. If problem exist within same production dates maybe Rome just got lucky with better assembly. But hearing from owners that doesn't have the issue makes me ask how can it be overall design
Edited by Cl Houn
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
