Steering wheel trim
Would anyone happen to know how to remove the horn/airbag cover so I can remove the metal trim ?
If you are planning to do this make sure to DISARM THE AIRBAG SYSTEM!
Rotate steering wheel counter clockwise to line up lower left hand spoke with the ignition key or lower right hand spoke with turn signal. From the backside of the steering wheel fully insert a small screwdriver or equivalent tool at a slight angle pointing towards the top of the steering wheel. Apply and keep constant pressure on handle as close to upper spoke above the metal steering wheel hook. Lift the screwdriver handle up to push spring toward the center of the steering wheel, at the same time pull out on the steering wheel airbag cover to release. Rotate and repeat the steps to release the other side. Release the connector position assurance (CPA) retainer. Disconnect the electrical connectors.
Do you know how to disable the airbag?
Disconnect the battery. I'm a firefighter, and we do this at all accident scenes specifically to avoid being hit by airbags while working in and around the vehicle.
What station are you with brother? I'm with 140 in esd5 Somerset tx.
But also wait 10-15 minutes after disconnecting because the airbags have capacitors that will store current for awhile in the event a battery is destroyed in a collision. Also a firefighter:)
In any event I personally wait at least 30 mins after disconnecting the battery to mess around with stuff near airbags. Those things have and can kill you if they go off while your in front of them.
Sent from my SM-N900T using Tapatalk
  • 6 months later...
Has anyone confirmed this on how to remove the trim? I would like to get mine removed
  • 2 months later...
I did it the easy way pull the volume/tuning buttons out (pry tool)
t20 take the screw out
Pulled the horn fuse(as u pull the trim out the horn will keep honking at u)
Then slowly worked it out....
There is 3 t15s that hold the buttons to the trim
It is alittle more difficult to put back in but with some motivation .....
I colormatched mine also[emoji106]
DEBAB6E4-28A5-4543-9754-DCCB9E0B00D7_zps
The removal is easy, but putting back in is a PITA. Hopefully someone can figure out how to remove the horn cover/air bag on the steering wheel which will make this easier in the future
I really like how the red came out on yours, it goes really well with the black interior
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
