Need advice to level rear of truck with front
My truck has 3" lift blocks in the rear and some type of pro comp lift shocks in the front (not sure bought truck with them) and 285-75-16 tires. Sits at 39" in the front and 38" in the rear to the middle of fenders. Should I go with a 4.5"-5" block to make the rear slightly higher like it's supposed to be or just a 4"?efb7aa3e7d4e44a9e5d3454f8c6c4c6c.jpg It's really noticeable at times and sometimes it's not but I find it really annoying. Thanks for the help. c13b5b3054f011e4ec72c701dbd5fa87.jpg090979ced45728c041b798e5383d967d.jpg
Sent from my Sierra
Well like all of us that are anal about the looks of our trucks, I would say that would drive me crazy as well. However, no body will really ever notice either and its a great looking truck...
I would check out your CV angles to make sure they're not too steep. If they look too steep then i would crank your torsion bars down an inch and go get a front end alignment. If your angles look ok then go with a 1"-2" taller block in the rear depending on the look you are going for. I like my trucks at least an inch higher in the back so it doesn't look so terrible when loaded down or towing.
