Really nice. Like the color match bumper. Good luck with it!
Yes, I've used touch out paint in a couple of places. The most noticeable was on the in the front of the front fender flare. The last place I would expect to get a ding. Anyway, I ordered factory touch up paint from my dealer, applied it, then polished it out with clear coat scratch remover. Not perfect, but hardly noticeable.
Yeah my parents dog decided it was okay to jump up on my door. you can barely notice it but i know its there lol didn't know if it worked decent or not
I hate that when it happens!
Here's mine after a fresh cleaning
This looks awesome man. What is your set up?
Rough country 2.5" leveling kit with 18 inch fuel Mavericks with 285/65-18 nitto trail grapplers
had a little break from the texas flooding weather to install my RC 2.5 level friday night and got the tires mounted saturday morning.
not the best pics but I LOVE it now...should have come like this from the factory.
photo%201_zpsasrdqufe.jpgphoto%202_zps0dayzmlp.jpglevel kit is RC 2.5
toyo open country MT 33x12.5x20
Hope you doing OK up in DFW...I had a break in the storms long enough to install my Corsa Exhaust...this flooding is real bad and some tornados around Austin too!post-106333-0-92423600-1432582262_thumb.jpg
Edited by chuckl1218
Thanks...safe here.
Saw video of flooding in Ur area and just west of Austin!!!!!! Holy crap!
I'm sure the exhaust sounds awesome!
Thanks...safe here.
Thanks...safe here.
I'm sure the exhaust sounds awesome!Thanks...safe here.
Yeah, 6+ inches of rain in 3 hours plus Tornados. Scary stuff. It's over for now and we are safe.
Cheers.
This is my GM-Trucks debut of my 2015 Sonoma Red Sierra. I previously had a 2008 Stealth Gray Sierra and I went dormant on this site for some time after completing all my mods. I became active again after I bought my truck this past March
This was taken after giving it an Adam's wash and coat of Buttry Wax yesterday.
post-50660-0-85117200-1432608325_thumb.jpgpost-50660-0-82223700-1432608357_thumb.jpgpost-50660-0-48212300-1432608385_thumb.jpg
well it finally stopped flooding here in DFW TX so I actually cleaned it up since installing lift and tires.
had to rearrange my garage so the truck would fit also...
few poser shots.
few poser shots.
Looking real good! I severely regret not getting the TOYO Open Country MT's
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
