New BFG All Terrain T/A KO2
Big Whiskey
  • Replies 110
Just picked up a set with some MB 352 Wheels 16x8.5" on 285/75/16 at Amercia's Tires. These rub but will be installing a Cognito 2.5" leveling kit to remedy...I love the look of the sidewall of the new tire very aggressive. I am glad I waited was going to go with Nitto's or Duratracs..
  • 3 weeks later...
What pressure are you guys running in these? I just got a set and the ride home from the tire shop was bone jarring. I checked them and they had 65psi. I lowered them to 50 and will try it out tomorrow. I know I shouldn't run 32 since they are E rated, but 65 seems excessive for a little half ton pickup.
I've mine at 37 cold psi front
33 cold for the rear. I thought they're D load/range. So far 8,000 love this tire
I think all the 20" sizes are load range D and the 18"s are E. I'll keep lowering them until they feel better. Thanks for giving me a base line. I can't believe how quiet these things are.
I say there a 32" b96a1595a866e5489add6dd93d296243.jpg 275/60/20
Interesting that the 275/60's measure out to only a 32". I need to measure my stock tires and see what they actually come out to. I've been going back and forth between the 275/55's and 275/60's. If the 275/60's are only 32" and my stocks are close to 32", I'll probably go with the 275/60.
I wish I could find out the actual measurements of the other tires I'm looking at.
  • 3 weeks later...
hopefully he measured that off the truck or front to back because top to bottom you can loose 1" with the tire squatting... just saying.
Anyone else have a snow review? Winter is coming. Well back again that is soon here in Oregon. Need some new rubber and right now I'm leaning towards the General AT/2 for its studdable option and low cost. But if the KO2 is in fact much better than the KO on ice I would be hard pressed not to go with them.
I love my BFG A/T's in the snow and ice! Best all around tire I've owned. Mine are a little over a year old though so they're the previous generation but I wouldn't imagine that they would have made them worse. Love the look of mine too and even more so the new ones. :thumbs: Don't have any experience with the General's but I wouldn't hesitate to recommend the BFG's.
I run about 40psi in mine.
Going to grab exactly what BOSS324 did. Adding them to a 2010 black all-terrain with a 2 inch lift.
Might want to double check....but I'm pretty sure a 17" rim is the smallest you can go on your truck. I don't think 16's will work.
Oh yeah? Because of the bolt pattern? Never thought of that. Thanks I'll look into that. I hope I can because I like the "meaty" look.
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 271 Guests (See full list)
