Correct me if Im wrong here but are the Fisher and western Plow mounts not the same ???
No they are not, the Western arms you simply pull the pin and the entire arm comes off leaving only the mount tucked up in the bumper.
The western plates sit a lot lower than the Fisher. IMO, Not enough ground clearance when mounted on a 1500.
But you just pull the pins and there is nothing hanging down.
That is true, but you probably won't be pulling the push plates until spring.
The Western PPs also hang our further than the Fisher.
Edited by George C
I like that mount. It's a lot nicer looking than my SnoWay mount. I like my SW because of the downpressure, but the mount annoys me. I smack it on everything all the time...curbs, parking stops, dips in the road. It hangs low.
IMG_20140915_175437968_HDR_zpsgcvt6rwf.j
IMG_20150928_143852305_HDR_zpshw9uq84y.j
Looks a lot like a Boss plow mount, I would love having down pressure for back dragging!
  • 2 years later...
How far out do the Fisher mounts stick past the bumper.  That may be a tough selling point for me, carrying around all that extra hardware and bumping into things in the summer
This is My 17 , Its the same Fisher set up that was on my 99 silverado, I keep updating , and painting, Mind you I don't do a lot of Plowing anymore , But at one time my account's numbered 30-35 residential . This last refit from my 11 to the 17, Side-plates were the same. just needed 1 wiring harness. I do the installs. I know mine does hang lower, but for me that does not justify the cost of new. Now if a v-plow would work on the 1/2 ton short box regular cab, that I would consider.
  • 4 years later...
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
