Stop the rub
Guest Can't Stop Now
I have a 2011 Sierra LSE 5.3. I have a pro comp 2" leveling kit installed. I just had some sweet 305/55/R20 installed on factory rims. I want to offset the tires flush with the out side of the factory fender using the factory 20" rims. I don't want more than a 4' lift. I need the gooroo to show me the way
Maybe 1/4 to1/2 inch wheel spacers would do the trick...? I'm no expert though. I run 275/60/20 tires on my factory rims (2008 LTZ +31 offset) and on +25 offset MB Motoring rims and do not rub at all. The 305 width is most likely your worst enemy. I'm sure others will chime in soon. Good Luck!
Ok. So are you wanting wheel spacers and more lift or a lift that will widen the track width? You really only have two options.
1. Body lift and wheel spacers if you so choose.
2. Complete 4" suspension lift like BDS or Zone.
