order tracker
When do the report that the truck is done right after it leaves the line or do they manually have to place it in the computer. be nice to have web cams to see the trucks being built live .
My truck never showed up on Chevy's Web tracker.
I just ordered a GMC 3500HD Denali last week and can't even get the GM connect order tracking site to work. Says it is offline. What site/link are you using?
I go into chevy.com then click where it says owner on the top banner then scroll down to order tracker . i went in and got the link http://www.chevrolet.com/order-tracking.html
but all it says is it's qued for production i was told the week of the 10th and the work day must be over it's friday and still no change . if any body that i sent my order # did you see it go by this week ? a tall order i know when they make how many thousands of trucks
I just realized, chevy and GMC have separate order tracking sites. The gmc one doesnt work. I am getting updates via thee GMC website chat function but sort of a pain.
For a Chevy 2500HD I ordered, the tracking system never worked. I finally did the chat/support link and asked about it and was told they knew it was down. The dealer can call a number for status. For my truck, it actually showed up on the dealer web site as "in transit" when it shipped.
I tried the chat they said a tpw of the 17th and my dealer said the 10th i asked if they knew where it was comming from but that part of info will happen monday when they open.
Pm the GM rep on here , Jennifer is great, get weekly updates automaticly, info usually up to date up until it leaves rail yard. Then you dealer will have better info. Just ordered my 2015 3500 chasis for hooklift saturday. Ordered a 1500 in the spring and the updates were helpful
Can you link me to her ?
do a member search for GM Customer , and send them a message with your order number and state
Hey cat320 and everyone,
As bruklnboy has mentioned, we can provide order status updates. Just send us a PM with your order number and we'll be able to check for you. Also, feel free to reach out with any questions. We're happy to assist!
Sincerely,
Eddie A.
GM Customer Care
Sincerely,
Eddie A.
GM Customer Care
Thanks i sent you a pm with the order number .
I called my dealer to see if they knew anything more and they said it is built and in the rail yard? still don't know where so order tracker still says waiting to be built . computers got to love them
The tracking system is a total joke, your dealer has all the updated codes as does GM, you can call either one and get the answer but using the tracking system will get you know where.
My truck still showed in transit 3 days after I took it home.
    • Good morning! I have a whirring sound coming from the engine or transmission area when driving w/o towing when I accelerate at 1100 rpm’s. That’s how it started. Yesterday it was more obvious while towing a U-Haul even when not accelerating at 70 mph. I could see where it may have been possibly shifting gears due to a slight grade and the intermittent rpm changes as the transmission was possibly lowering the gear down. It was making the sound multiple times but it is not constant. I replaced the serpentine belt and idler pulley but no change. It only does it when I’m driving. No noise accelerating while in park. Just started @ 53,000 miles. It’s not always there though. Unfortunately, I feel it may be transmission related. Any thoughts or knowledge about the 2022 tranny that anyone can share. I have 2500 miles left on my p-train warranty. Thanks to all for any help!
    • RAIN. It's dumping buckets. We needed it. What a welcome change...sitting here listening to it pour with my office window open.   Ok, not too much. It's not even September yet, we're not finished with summer yet....
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
