2014 ltz seat settings!! back breaker
diggman08
has anyone else had issues getting their seat adjusted to the perfect postion. I seem to cant find it.. just 20min driving this thing and my back is killing me. leg gets numb. so when I took it in for service, they gave me a 2015 SLE loaner. perfect setting much more comfortable than my leather 2015 LTZ.
I haven't compared to any other trim levels but yes, I'm not going numb or anything but the pedal distance is hard to dial in and it doesn't seem like the front of the seat goes low enough. Seems like I've been playing with it for six months straight.
It took some tweaking over time to get my seat set to perfection, now it is set in memory. My pedals are extended fully away and the telescoping wheel fully extended toward me, the front portion of the seat is all the way down and lumbar deflated. I like to sit low with my knees bent, stretching out doesn't work for me, BTW, I'm 6'3"
I have mine the same way, wheel out, pedals back, still feels like I'm too close to the brake but oh well.
on the left side behind the tilt (vertical lever) is the wheel telescoping lever. it's a horizontal lever.
no, I have heated wheel and telescoping. that's weird, there's a good picture of it in the manual.
do you have the adjustable pedals? thinking it could be part of that option package. mine's ltz also.
weird. pretty sure I don't have that option. but I have a loaded LTZ.. I wonder if because the heated steering wheel
you don't get the telescoping?
Seriously? You don't know if you have that option??????
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
