I had to have mine road force balanced. They needed alot of weights to balance. Could have been my new wheels too.
They ride smooth now at 38psi cold.
I have 275/65r20 on 2 1/4 leveling kit and don't rub at all on a 2wd.
Please post some pics of this set up. I'm trying to decide between the 275/60 and 275/65-20 size.
me too
beautiful...i think i really want the 65s for the extra meat...but im not cutting or banging or trimming a new truck like some art project...now do i flip the page for the 285/55/20 for the extra width instead? wtf lol
Haha I felt the same, but no trimming with this size. But of course it would look a little better with the 285's but then comes the art project
the 285/55/20 will also fit with no trimming or rubbing with level
I narrowed my choice between the KO2's and Duratrac's. Went with the KO2's in 275/70/R18 on my factory wheels. I think they look great!
You ran the OWL on stockers like a boss!! I've been looking at rims (like the Fuel PVD Nutz), but IMO that stocker has a unique pattern that really compliments the truck. The new KO2s look really nice, but I'm concerned about that 60+ # of weight....what's the seat of the pants feel with the new tires (acceleration, braking, ride)?
Thanks! I'm real happy with the way it turned out. I haven't noticed anything in the acceleration, but just a little bit on braking. The ride is still nice and smooth. If you really "try" to notice the difference, there is probably a slight amount of stiffness from the tires. These small trade off are will worth the great looks and increased traction come this winter. You won't regret it.
I'm looking at getting these but I noticed that each tire is 16lbs heavier than the stock Goodyears is that gonna result in ball joints etc wearing out quicker and am I going to lose any towing capacity? I have the 4.3
You will lose mpg. Component wear? Maybe slightly do you have a level kit?
Ryan
No sir I do not I want one but it's a lease idk how my dealership feels about it the service guy said it's ok it won't void anything but some can be a little bit of a liar I am thinking of putting one on tho will that benefit me or make it worse in component wear
I have a 2015 all terrain with a 1.5 inch RC leveling kit. I've seen the pics of guys running 275 60 20 bfg all terrains at stock height and was wondering if I could get away with the 275 65 20 size?
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
