Haven't seen it asked yet and it's entirely possible I missed it.
Love this tire and am wondering will 275x70x18's fit with stock suspension and stock Z71 wheels? Bilstein 5100's are in the near future but do I need to wait to level first? These stock SR-A's are killing me. lol
Thanks
Thats what I am looking at as well. If you do it, post it up. I'd like a level, but have to find a way to sneak it by the wife...she's pregnant and will for sure notice haha
I literally just went on a rant about how shitty the stockers are in the rain with nothing in the box.
Hey guys, just joined this site. I'm from Wpg, Mb.,Canada. Just picked up a '15 All Terrain and I'm leaning toward the KO2's in the 285/65-20 size. Had the dealer install a 3" Readylift front and back. Been running the original KO's for the last 13yrs on my '03 Sierra. Love them in the winter cause up here inthe North Pole ' we get lots of snow.
Edited by MoneyMaker
So I was just told that gm and Goodyear only recommend using the sra stocks for the 4.3 v6 has anyone heard this? I really want the bfgs so I might just ignore they said that lol
Yea that is bs lol they only say that cause they'll make a killing off replacing the sra's every 10k miles
I'm also in wpg Canada with a 15 all terrain buying these on Monday
Sent from my SM-G900W8 using Tapatalk
LOL
Who told you this?
Ryan
Lol I honestly could of sworn I read it on here somewhere in a different thread can't be 100% sure tho definitely didn't actually believe it but needed reassuring lol
Anyone got pics of these in a 275/70r18 with leveling kit
Here ya go:
I just got mine on Friday. Had them mounted on my all terrain wheels powder coated satin or semi gloss black. 275/60/20
Edited by Dropsix
Sorry screwed up the quote and can't fix it quick.. Is that without level dropsix?
Yup no level. They fit perfectly fine.
I'm thinking a 1" lift all around just because I think it would look great.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
