i recently ordered a bulk shipment of summit white automotive vinyl through a local supplier. I have quite a bit left that I'm not going to use ( i covered my grille, front and rear bumpers, mirror caps, and handles in it) So i figured id see if anyone on here was interested in the remaining roll ( i have 8ftX20ft roll left in perfect condition) Im looking to get $100 for the roll which i think is pretty reasonable as i paid around $400 for entire roll when i ordered it which was 8ftx40 originally. Let me know what you think and if you have any questions.
Thanks :thumbs:
I'm only looking to do my mirror covers and handles... You want cut and send me some? Shoot me a Price?
Sent from my XT1058 using Tapatalk
im located in Illinois, it is automotive vinyl that has a special backing that has "air release" properties. therefore all you have to do is apply a little area at a time and smooth it out, then using a heat gun heat the area and any bubbles it may have will disappear. the best part is its made for "beginners" so if you mess up or crinkle it all you have to do is lift it up, go over it with the heat gun briefly and the material will return to its original shape.
Man I want this...but I'm too scared of the install and messing it up.
you really can't mess it up, honestly, this style vinyl is a "beginners" style so it has allot of forgiveness. Look up some videos on youtube. if you you mess up a piece literally all you do is lift the vinyl, run over it with a heat gun and it lays flat again just like it was when you started. Its pretty neat seeing it do it actually.
I'm more concerned about cutting around the plastic trim inserts and such on the bumpers for a perfect fit...
oh you don't cut around them, take the plastics off; clean the bumper real well with a ammonia free cleaner and start wrapping then reinstall everything. Stuffs great, shines just like the paint, its wax-able just like paint, ect...
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
