Putco Luminix Fog Lights
  • Replies 44
so here they are. they are cleaner that they look in the front pic. the light streaks are from my phone camera, they aren't that bad in person. they are really really bright. almost dont need headlights now. im really happy with them. worried about blinding people now
is the lightactually usable light or just brighter and thrown all around?
looks like they have a projector built into the tip?
Its definitely usable. I think strictly as a fog light pattern, factory is better. These are bright and throw more light out all over. And yes, there is a projector lens built into the end. Works well
more forward direction of light? mine OEM are fairly useless.
I think this pic should help
8b62cc9fa71d5d2715e6fafc601eaa03.jpgthats just the headlights
94d1d4719578abf14747e3e2f6ed6780.jpgwith the fogs on with headlights. I put different bulbs n for the headlights yesterday they are much better then the stock one's
definitely more throw than stock. thats probably due to the projector on the end of the bulb. but there is just more light in all directions. when driving through my neighborhood they light up the houses completely on both sides, where as the old ones would just light up the lawns and nothing higher. ill try and get a good pic, just hard to show with a cell phone cam.
I probably would not drive with them on all the time or else you will blind people. Since fog light output isn't directed by a shield of any kind its very easy for fog lights to get in peoples side, and rear view mirrors causing unwanted light to reflect into a drivers line of sight.
You think you could post a link to find those lights? Very interested in trying a set after seeing your your results
nope. just took the old ones out and popped these in. very easy
Did you have to perform any modifications to install these ?
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
