Huskys up front. WT in the back. Wish i did that my boss has it like that cause of my tip... in the spring im thinking of order the Huskys for the front. Use the wt for winter. Idk
Nope, no skid plate here [emoji34]
Looks to be the same bolt pattern as the skid plate I took off my 02. May touch it up with some paint and stick it under there just because this truck is so much lower
Sent while in 'Murica...
Did you by chance see if the old one fits? Would be a great thing if you could buy an older model plate for these new trucks. There was a thread looking for aftermarket metal plates. I'm sure it wouldn't be a perfect fit, but if it was close, would be a good option.
And, Nice truck :cheers:
I can check to see if the holes line up tonight
Alright, probably in the next couple weeks I'll be installing my 2" level kit (front only) from Top Gun Customz. Going to do it on a Sunday so I can drop it off Monday morning for an alignment and get it back the same day. Now Im on the hunt for wheels and tires. Figured I'll start looking now so I know what to save up for and get in probably a year or so. Looking at GMC Sierra All Terrain replica wheels, the ones with the matte gray and gloss black:
http://www.oewheelsllc.com/Wheels_3/Wheels-for-Chevy-Trucks/20-Fits-GMC-Sierra-1500-Wheel-Black-Machined-Face-20x9-SET
Im not decided on tires yet. I would like an all terrain tire, but would still like to maintain most of the silence in the cab. I know I will have to sacrifice some of it for better off road performance though. Not a fan of the BFG All Terrains. Had them on my last truck and they were great at first but once they started wearing, they went quick and really lost a lot of traction. The Dick Cepek FC-2's on my lifted truck currently werent too bad, except they basically have been slicks for the last 5k miles. If yall have any suggestions on a good all terrain, or maybe even a quieter mud terrain tire, lemme here em!
Also plan on installing some footwell LED lights, as well as some lights inside the step of the rear bumper. May also get some tabs installed on the hitch to put some LED's so hooking up a trailer at night isn't a struggle.
Since I removed the problem-ridden HID's, I may get some VLED high, low, and fog light bulbs. They are expensive, but from all the reviews Ive seen around the interwebs, they seem to be worth it if you have the money
Cleaned her up and added my first sticker [emoji108] a2c71157a3c88abf6ea37b4cc0bca59a.jpg5af756efc8fb9260c0b3209d9e1497ae.jpg
You better level that truck up or that sticker is going to fall off
I'm going to setup an alignment for next Saturday morning and hopefully install it the night before. I also am going to play on paint with the pic of the truck and see what I should debadge. The chrome trim on the doors is already starting to chip up
That's better my finger was on the ban button. Lol
That sticker is looking good. I have the same one on the way. Hoping it comes in this week so I can wash my truck and put on the sticker this coming weekend. And how is the trim on the door already starting to chip? What have you done to it? lol jk. But thats way too soon for it to start chipping. I would personally leave the strips and pull off the high country badge. Clean up the doors some.
I can do that too... now don't you forget lol
Edited by rdnckhntr94
I'm going to play with a couple different ideas i have in my head in MS paint tomorrow. I'll post em up, but since the chrome is already pitting, those trim pieces are coming off. I would like to keep them on cause they keep my door from getting dinged but right now they don't look like they'll last much longer lol
A dealer would probably replace them for free since they are pitting so soon. Just a thought if you really do want to keep them!
I'm weighing my options first lol no rush to debadge
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
