Look ugly as hell tbh
I wouldn’t call them “Ugly as Hell”. Maybe they’re just a bit more sophisticated for you than you’re used to. They’re 1 out 3 of the hottest selling Fuel wheels for 2018. I’m actually running them right this very moment and get endless daily compliments on them.
They’re good looking but around here the black wheels or even machined black wheels on a white truck are so overrated and everyone and their cousins has the same looking set up
Totally get it, I too was a bit apprehensive but wanted to breakup the white/chrome look a bit and they’re much easier to maintain versus chrome and aluminum. IMHO, I have to agree with you on the blackened out wheels, don’t look good at all, cheapens the look of a loaded out truck. But, to each their own.
Here’s my 18,SLT 6.2
of course they are sideways!.... got new BFG TKO2's.   275-60-20.... the fit is perfect.. no rubbing.. got about an 1's from the wheelwell wall on full turn... i think anything bigger would rub like crazy!
56479093541__DDDC7917-A4DF-4F8B-A23B-F2025CB0610A.JPG.c3935d6d18791bcd49c40ad853281a37.JPG56479101300__D0A39418-4C9E-4192-9777-062AF54F1937.JPG.04652b3ea262959168fd0f0a19213777.JPG
Looks great! What’s your setup?
Thanks Bud, just a 2' level in the front... nothing special... nfab steps, uws toolbox, 32' light bar, flowmaster super 10 dumped, and k/n intake... .. i keep it pretty stock... but looks clean!... above is without the new, BFG"s.. ....and my driveway has a little lean..
Edited by Crstfr
Looks great! I got rub after a 2.25” level on mine with just 275/60/20’s KO2’s.
no fooling?.. hhmm yeah i haven't heard it rub or felt it through the wheel yet.. the level was put on by the dealer when i got the truck.. they put on the tint, level, tool box and steps... i believe its a 2'..... i'll check after work at full tilt and see whats going on.
You may have different offset wheels. I had to get new wheels with plus 1 offset.
hhm.. yeah kept stock rims..
Definitely weird there cause it’s very well know that late 15 and up have the “cursed” new stamped steel UCA’s causing rub as soon as you level. You’re definitely a very lucky guy not getting any rubbing with same setup I had. Good looking truck!
    • I agree. That`s a LOT of sludge for 12,000 miles. I tossed that out here since this is an OCI thread. There`s tons of people here that do not post.   I used to work on a city fleet. That includes police cars and fire trucks. Lesson is, not to only use the odo for oci. A police car has a ton of hours on the engine for the miles it shows. And, not just idling, directing traffic. They beat on these things.   Course, since it is a Kia, they were gonna use the "100,000 mile warranty" for their OCI.😉
    • CLASS ACTION SUITS?  Does anyone know if there is already a class action suit for the paint - which was to have been fixed, changed in after the 2020 GM vehicles?  Does it look like this?    Just started 3 weeks ago - No help from GM as of yet - Dealer will not assist in speaking with GM on my behalf. Confirmed it is the paint they use along with the way the put it on that causes it to fail.  Clearly a Manufacturer's Defect.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
